Thread: Anyone install transmission drain plugs?
Results 1 to 20 of 28
  1. #1 Anyone install transmission drain plugs?
    Oct 2011
    Toledo, OH
    All the brands look pretty much the same. Some have nylon washers, some have metal ones. Anyone use them and have any info about them? One youtube video says to just snug it down, but I'd think you'd probably want to mash it pretty good. Any thoughts?
    7"
  2. #2 Re: Anyone install transmission drain plugs?
    I have a ZZP one and a buddy has the dorman one. Aluminum vs steel. I think I like the way the steel is done better
  3. #3 Re: Anyone install transmission drain plugs?
    I break stuff selliott's Avatar
    Kansas City
    I agree with bill
  4. #4 Re: Anyone install transmission drain plugs?
    Oct 2011
    Toledo, OH
    Didn't see any aluminum ones, but wouldn't get one anyway. More wondering about the washers. Some kits have one, some have two, some are metal, some are nylon.
    7"
  5. #5 Re: Anyone install transmission drain plugs?
    I think the dorman one uses an npt bolt and calls it done. The aluminum ZZP ones.. are often prone to leakage
  6. #6 Re: Anyone install transmission drain plugs?
    Oct 2011
    Toledo, OH
    Looks like they are all NPTF but I went with the Jegs one because it uses a metal washer on the pan side nut.
    7"
  7. #7 Re: Anyone install transmission drain plugs?
    Enfield, CT
    i'm thinking of tapping a plug into my OEM trans pan. I'm probably gonna do it on my spare one to test it
  8. #8 Re: Anyone install transmission drain plugs?
    Do you need another Kyle?
  9. #9 Re: Anyone install transmission drain plugs?
    Arizona
    Doorman is steel with drain plug included for 35bucks
  10. #10 Re: Anyone install transmission drain plugs?
    Enfield, CT
    Quote Originally Posted by 91parkave View Post
    i saw that but I wanna try to make one first since I have a spare one
  11. #11 Re: Anyone install transmission drain plugs?
    Oct 2011
    Toledo, OH
    Says it doesn't fit the HD transmission, not sure why that would matter though.
    7"
  12. #12 Re: Anyone install transmission drain plugs?
    Arizona
    Quote Originally Posted by industrialfish View Post
    I used rock auto they list the pan for the GXP which is the same exact transmission...
    Here it is installed.
  13. #13 Re: Anyone install transmission drain plugs?
    GT Level Member gpbastard's Avatar
    Florida
    can you use a factory AC Delco gasket with this pan?
    gpbastard
  14. #14 Re: Anyone install transmission drain plugs?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by gpbastard View Post
    Yes.
    7"
  15. #15 Re: Anyone install transmission drain plugs?
    May 2016
    Lincoln, Nebr
    I was think of adding that Dorman pan (pn#265-814) with the drain plug on my '08 GP. I also thought it would be smart to add a FilterMag TM180 on the outside of the pan, so when I drain it later between filter changes I can remove the magnet and hopefully get some of the metal shavings to flow out through the drain plug along with the fluid.
  16. #16 Re: Anyone install transmission drain plugs?
    Enfield, CT
    Not at the moment Bill. If I do it successfully, I'll probably do a write up
  17. #17 Re: Anyone install transmission drain plugs?
    It's the same pan. Heck..you can even use a 60E pan if you really wanted. Holes are slightly bigger, that's all
  18. #18 Re: Anyone install transmission drain plugs?
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    I just welded a nut with a flange in there and used a drain plug from a motor I tossed out. Worked great and was FREE! Sucks trying to drain them any other way unless you have a GIANT catch pan...
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  19. #19 Re: Anyone install transmission drain plugs?
    Enfield, CT
    Quote Originally Posted by Kejross View Post
    sounds like a better idea lol
  20. #20 Re: Anyone install transmission drain plugs?
    I do have that giant catch pan.. but ehhhh swap and smile.
  1. Dorman Transmission Pan With Drain Bolt.
    By Brammer in forum General Grand Prix Discussion
    Last Post: 10-18-2013, 06:21 PM
  2. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  3. transmission drain
    By mhartwig in forum General Tech Discussion
    Last Post: 11-22-2010, 07:40 PM
  4. SD headers/plugs/t-stat/3.4/tune install w/pics
    By Boosted02GTP in forum General Tech Discussion
    Last Post: 10-30-2010, 10:29 AM
  5. radiator drain o-ring size? FAILED motormite drain.
    By alacran in forum General Tech Discussion
    Last Post: 04-03-2010, 08:16 PM
