Thread: TEP shift kit + ZZP PCM with modded line PSI = ?
Results 1 to 16 of 16
  1. #1 TEP shift kit + ZZP PCM with modded line PSI = ?
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    having that combo is it bad for the trans? I dont want to run to much line pressure and kill it. I noticed black clutch like material in the fluid but no burnt smell.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #2 Re: TEP shift kit + ZZP PCM with modded line PSI = ?
    How much added psi. How firm are your shifts?
  3. #3 Re: TEP shift kit + ZZP PCM with modded line PSI = ?
    Apr 2012
    Middletown DE
    Quick but not tooth chipping firm, even at wot. I sent an email to Zoomer to figure out how how much more PSI he adds to the tune. Will see if he replies..
    1993 Oldmobile 88
  4. #4 Re: TEP shift kit + ZZP PCM with modded line PSI = ?
    sounds like you are fine to me. I know plenty of guys that have done it.
  5. #5 Re: TEP shift kit + ZZP PCM with modded line PSI = ?
    Feb 2009
    flintnasty MI
    Shifting this hard will strain your inputshaft and chain more.
  6. #6 Re: TEP shift kit + ZZP PCM with modded line PSI = ?
    Apr 2012
    Middletown DE
    OK I noticed a lot of black material in the fluid but doesn't smell burnt or shift weird, I think it is the torque converter coming apart. I was told when I had the trans out for the TEP stage 2 install 2800 miles ago that the trans got so hot that the TQ Converter burnt off its paint of and started to rust..
    1993 Oldmobile 88
  7. #7 Re: TEP shift kit + ZZP PCM with modded line PSI = ?
    And you reused it?
  8. #8 Re: TEP shift kit + ZZP PCM with modded line PSI = ?
    Apr 2012
    Middletown DE
    And you reused it?
    haaaaaaaaaaaaaaaaaaaaaaaaaaaaa yes. I know.. ever hear the term "ill save money no matter the cost"? that's me right now..
    1993 Oldmobile 88
  9. #9 Re: TEP shift kit + ZZP PCM with modded line PSI = ?
    Apr 2012
    Middletown DE
    1993 Oldmobile 88
  10. #10 Re: TEP shift kit + ZZP PCM with modded line PSI = ?
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    I've got the PCM and the added spacers n springs in the Transgo shift kit...seems firm so far, slight jerk in shifts when accelerating to 3k with no boost and it can kinda jerk into 3rd.
    1998 Grand Prix GTP Daytona - CAI, XP Cam, Iceman tune, Speed Daddy Headers, 3.2 in pulley, Ported blower, Al 103's, 3in Catless DP, Transgo "shift kit", No resonator to Magnaflow Mufflers. 93K Miles
  11. #11 Re: TEP shift kit + ZZP PCM with modded line PSI = ?
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    I was going to ask the same question as Bill....And you re-used it? Crazy to think that you sink $2500 into this awsome built trans and cheap out on a reman converter that you could get for $125. Lesson learned.
    I rarely re-use the converter unless the fluid and material in the pan looks amazing....and even then if I'm dropping that kind of money on a built trans I still spring for the reman converter.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  12. #12 Re: TEP shift kit + ZZP PCM with modded line PSI = ?
    Something to think further about..
    In the spacer plate between the valve body and channel plate are two little filter baskets. The fluid flows from the pan into the filter, through the pump, into the converter and then through the valve body and channel plate.
    If your converter is self destructing, you may already have debris in your valve body and those filters. May be a good idea to have someone go through those pieces to ensure they are not compromised while it's out for the converter. Otherwise you might end up taking it back out again.
    Trust me on this.. I'm the master of having a trans out of a car in two hours. There's a reason behind my being good at pulling them.
  13. #13 Re: TEP shift kit + ZZP PCM with modded line PSI = ?
    May 2008
    Schuyler, NE
    Geez! How the hell do you get one out in 2 hours?
  14. #14 Re: TEP shift kit + ZZP PCM with modded line PSI = ?
    Apr 2012
    Middletown DE
    experience. I had a blown engine out and new one installed and running in 4ish hours
    1993 Oldmobile 88
  15. #15 Re: TEP shift kit + ZZP PCM with modded line PSI = ?
    Apr 2012
    Middletown DE
    Thanks for this info, i will take it apart myself and see what i can do. I will pull it out next weekend
    1993 Oldmobile 88
  16. #16 Re: TEP shift kit + ZZP PCM with modded line PSI = ?
    mine was on the floor in 1.5 hours, at Bills house of course. i was amazed. the whole swap took 4 hours.
  1. Replies: 1
    Last Post: 12-08-2012, 07:39 PM
  2. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  3. GTP vs. Modded 04 STi
    By ninnyGTP in forum Track Sessions and Kills
    Last Post: 06-07-2010, 10:42 AM
  4. 01 GT, just modded
    By mzendano in forum Visual/Body Modifications
    Last Post: 04-12-2010, 10:05 PM
