Thread: Transmission flush?
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
  1. #1 Transmission flush?
    Jun 2013
    Michigan
    I have an 04 Grand Prix with 192K on it. I bought it a year ago and put 35K on it since and noticed that my trans fluid is a little darker but doesn't smell burnt at all. I was thinking about doing a flush but don't know how healthy that would be on this tranny. I don't know if the last owner did a flush regularly so that makes me nervous. It doesn't slip...maybe shifts slightly hard every so often on the last gear if I'm accelerating slowly. Any info would be greatly appreciated as I'm not sure what to do. Maybe just drain, change filter and add Lucas trans fluid? Thanks
  2. #2 Re: Transmission flush?
    Dec 2012
    Where 4T65E's were born
    Just about everyone on this site will highly advise against a flush, especially past 100K miles with no knowledge of past maintenance. A pan drop would be the best route, but even then at much higher mileage can be risky. Others will chime in on this, I'm sure of it.
    Sold.
  3. #3 Re: Transmission flush?
    dont flush it. pan drop filter, add the lucas if you like. a shift kit may fix that hard shift you have too.
  4. #4 Re: Transmission flush?
    Aug 2012
    westlock alberta
    whats wrong with flushes?
  5. #5 Re: Transmission flush?
    Ohio
    Quote Originally Posted by jrvl93 View Post
    When a transmission is flushed, it rids it of all the clutch material in the fluid that the transmission needs to work properly.
    Many have needed to get a new trans after having a flush done.
    Best thing to do is a pan drop and change the filter.
  6. #6 Re: Transmission flush?
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Not to derail the thread to much but is it worth it to put in a shift kit in a tranny with this kind of mileage? Im at a cross roads as well with 185k and know that a service is due... Do I invest the money in a shift kit because the way I see it, if we are gonna drop the pan and do a filter job might as well get the shift kit too righhhhtt???
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  7. #7 Re: Transmission flush?
    Aug 2012
    westlock alberta
    Quote Originally Posted by MoarkatsINmuhtrailer View Post
    oh wow i didnt know that is there a thread that explains this im curious why this happens and why it needs that material. is it just the 4t65's that do this? ive done flushes on pretty much every gm non transverse transmission and never had a problem.
  8. #8 Re: Transmission flush?
    If you change 80% of the fluid to fluid without that liquid clutch, how is that any different than a flush?
    The main concern of a flush as far as I know would be dislodging buildup that continues on to clog other components, thus rendering the transmission useless.
  9. #9 Re: Transmission flush?
    Jul 2013
    San Bernardino,Ca
    Just picked up mine from shop and they told me they flushed it and didn't change the filter. Why the #uck would they do that after I told them not to flush it. And why not change the filter??!!
    How long do u think till I need a trans?
  10. #10 Re: Transmission flush?
    Jul 2013
    San Bernardino,Ca
    Btw I drive 600 miles a week
  11. #11 Re: Transmission flush?
    Quote Originally Posted by kingspadeshan View Post
    how high are your miles? and was it ever serviced in the past?
  12. #12 Re: Transmission flush?
    Jul 2013
    San Bernardino,Ca
    I barely bought it last week and no idea what's been done to it. It only has 82,600 miles on it.
  13. #13 Re: Transmission flush?
    that fairly low miles, if the fluid was nice and red still theres a good chance you'll be ok.
    i would so give that shop a verbal lashing, and make them refund me, for not doing what i asked them to do. and putting you at risk.
    most shops wont do the flush if the miles are high, or the fluid looks bad, as they know the trans can die from it. at least they should know that.
    a friend worked at a lube place, they wouldn't do a flush due to miles on a guys car, he insisted they do it, they made him sign a waver in case the trans took a dump. that car left the lube shop on a tow truck. not kidding one bit. he put it in gear and had nothing, and i mean nothing.
    i was standing there hanging out, hes like watch this, showed me the waver and laughed, he goes that guy will be lucky if he makes it home.....lol
  14. #14 Re: Transmission flush?
    Jul 2013
    San Bernardino,Ca
    Well lucky for me none of it cost me a dime. The dealership I bought it from is taking care of it.
    So I shouldn't be worried? What about the filter?
  15. #15 Re: Transmission flush?
    Jul 2013
    San Bernardino,Ca
    I guess a better question is should I trust the digital temp reading on the DIC?
    What's normal?
    Mine hits 248 once in a while but is usually in the low 200's
  16. #16 Re: Transmission flush?
    if the trans feels good like it did before, or better, id let it go for now. do a pan drop and filter in 30,000 miles from now, seems like you'll be there in a year or so with 600 miles a day. thats a lot of driving. where the hell you going? 300 miles each way to work? thats got to suck.
  17. #17 Re: Transmission flush?
    Jul 2013
    San Bernardino,Ca
    120 round trip to work and back X's 5 days a week and yes it really sucks but pays good
  18. #18 Re: Transmission flush?
    200 is ok, the 250 not so much, is that in traffic? if its hot where you are, i see cali, not sure of the town, maybe put a trans cooler on. they keep the temps in check.
  19. #19 Re: Transmission flush?
    Jul 2013
    San Bernardino,Ca
    It's been really hot here lately. Southern Cali, I work in Palmdale. Been triple digits but I wasn't in traffic. I rarely hit traffic either way
  20. #20 Re: Transmission flush?
    Jul 2013
    San Bernardino,Ca
    How accurate is the DIC?
  1. Transmission flush. Yes or no?
    By Iceman83 in forum General Grand Prix Discussion
    Last Post: 02-15-2013, 11:56 AM
  2. To flush or not to flush?
    By 7point62 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-24-2011, 11:41 AM
  3. Transmission Flush
    By Lion29GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2011, 04:03 PM
  4. Transmission/ Coolant Flush Question and Problems
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 07-17-2009, 03:03 PM
  5. The Reason That Your Transmission May Act Up After a Flush
    By njbrain in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2008, 07:53 AM
