Thread: transmission compatibility concern
Results 1 to 4 of 4
  1. #1 transmission compatibility concern
    Money vortex synysterjoe's Avatar
    Mar 2013
    Columbus
    I have a friend of mine that needs a new trans for her 03 impala with the l36. We found a donor out of an 03 3.4 impala. I did a quick search but found conflicting information on whether this will work properly. I'm pretty sure the gear ratio's are different. Not a problem, I just need to know what gear ratio the 3.4 4t65 has. Also, I found that the torque converters are different between the 3.4 and 3.8's. True?
  2. #2 Re: transmission compatibility concern
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    Dave at TEP woudl be the best to ask about the. The only difference I could see in TC is the stall.
    97 Bonneville SE Not so much a 97 anymore
  3. #3 Re: transmission compatibility concern
    Mar 2013
    Columbus
    Just did, don't know why I didn't in the first place. hm. need more coffee
  4. #4 Re: transmission compatibility concern
    If the gears are differnt, swap diff. tc...likely isn't enough to matter
  1. Over-Drive Concern
    By brandonl2000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-01-2012, 02:52 PM
  2. NEWBIE with concern 2004 GTP
    By lobos in forum Introductions/Noob Questions
    Last Post: 10-19-2010, 12:29 AM
  3. Hey just a concern
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 08-15-2010, 02:41 PM
  4. Transmission shift solenoid compatibility
    By BackInBlack in forum General Tech Discussion
    Last Post: 10-18-2008, 01:19 PM
