was out doing some spirited driving and suddenly lost all gears. there's a whining/whirling sound that seems to come from the tranny to motor and driver side wheel area. towed it back to the house and scanned the ISS via powertuner to narrow down the cause. was told at park/neutral it should be zero but in gear be slightly lower with the RPMs. well in any gears its still at zero. the fluid isnt burnt and the level when car is running is between the words max operating. the tc bolts are still connected to the flexplate and the tc is spinning with it. so right now any ideas on what it might be? heres the setup on the trans and such:
triple edge performance strip/street trans-has just under 20k miles
300m input shaft(20k plus unknown mileage)
1" GM chain(20k plus previous unknown mileage)
miziere flex plate(used)
precision 3k stall converter(20k miles)
