Thread: Hey just a concern
Results 1 to 11 of 11
  1. #1 Hey just a concern
    GT Level Member AmericanRiceEater's Avatar
    New York
    Hey just about an hour ago i was leavin my dads house and my car wouldnt catch ignition after a few tries. I never had this problem before. I just got my new 3.4" set up about 2 weeks ago so im not sure if this is something that i should expect every here and there (my car not catchin ignition off the first 2 tries). My plugs are brand new but the ignition wires are stock and so are the coil packs. I never thought those could be a problem as far as ignition went, but am i wrong? Also i don't need bigger fuel injectors with just a 3.4" set up do i ? Or is this something that just happens every here and there with more boost involved ? Thanks my select few
    Black 2000 GTP Coupe. SSAutoChrome headers, K&N Cold Air Intake, Reptile Tuned PCM, 3.4" ZZP MPS, 104 Autolites & 180 Stat.
    PS3 Online: Zirpola (Dont use mic.)
  2. #2 Re: Hey just a concern
    are you priming the fuel system before start up.
    maybe your fuel pressure is low at start up and cant get the fuel in there right away.
  3. #3 Re: Hey just a concern
    New York
    I did rev my engine to about 2500 rpms before a couple launches tonight... can that be a reason ??
  4. #4 Re: Hey just a concern
    Jul 2008
    sumter,south carolina
    fuel filter?
    02 GTP with mods 05 GP for DD
  5. #5 Re: Hey just a concern
    Nov 2009
    Grand haven
    check for spark first. if your cps is going bad that may happen. second check fuel pressure at KOEO you should see 45-52 IIRC.
  6. #6 Re: Hey just a concern
    New York
    Ok.
  7. #7 Re: Hey just a concern
    Jul 2008
    flip key back and forth a few times before turning the engine over ... prime it up good and see if it starts on the first try
  8. #8 Re: Hey just a concern
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    with a 3.4 you dont need larger injectors.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  9. #9 Re: Hey just a concern
    New York
    I didn't think so. I havn't tried starting it yet today but im sure shes ok hopefully.
  10. #10 Re: Hey just a concern
    New York
    Ya it's workin fine, i prob just have to get some new wires and coil packs theyre gettin old
  11. #11 Re: Hey just a concern
    Jul 2008
    check the cheapest things first... get ur fuel pressure tested and go from there.... im guessing its a fuel delivery issue.
