I am a new owner of a 02 Regal GS and the seller told me when the HD trans blew he replaced it with a 02 LS transmission with a HD differential. It hasn't been driven that much because it had front suspension problems but the trans shifts funny sometimes and the SES light is on. While getting new struts the mech pulled the codes and said I had one for the VSS. Where is the VSS located? If I need to replace it (it might be disconnected) should I replace it with a HD VSS or a n/a VSS or are they the same?
Thanks
