Thread: Amp replacement
Results 1 to 6 of 6
  1. #1 Amp replacement
    Jan 2013
    United States
    I have a 2005 GXP and I am thinking that I lost a channel on my amp because the drivers door speaker makes no sound and the other 2 front speakers pop at higher volumes (if the amp isn't the problem, please give me ideas). The problem I am having is that I would prefer to replace it with the factory monsoon amp because I have heard other amp will lose the dash speaker and I am finding plenty of the amps for sale but none of them match the part number of 10395208. I found one with part number 10340134 for a good price but will that fit? Or is there an aftermarket one that will work?
  2. #2 Re: Amp replacement
    Jan 2013
    United States
    Oh come on! Somebody has got to know something....
  3. #3 Re: Amp replacement
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    I personally have not had any experiences with the GXPs so I really can't help you out but if I was in your situation I would switch the speaker with one you know that works (pass door speaker) just to rule out that the speaker itself is bad.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  4. #4 Re: Amp replacement
    GM Parts Direct: 10395208 - AMPLIFIER
    Looking for a price lower than that?
    If you wanted to diagnose the system you'd need a multimeter at the very least.
    Check for signal coming out of the amp to the speakers. If you have signal there, check at the speakers. If not, wiring issue.
    If you didn't have signal at the amp, check the input to the amp.
    If no, check the radio. If yes, likely an issue with the amp.
    I'm inclined to agree with the above post: Investigate the possibility of a damaged speaker/driver.
  5. #5 Re: Amp replacement
    Jan 2013
    United States
    I have alrady tried switching all 3 of the front speakers with new ones with no change. Thanks for the replies
  6. #6 Re: Amp replacement
    Yoga city
    pop a 9 volt battery to the speaker itself, if it moves its good if not its amp or signal to amp causeing no sound
  1. PCV Replacement
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2010, 03:21 PM
  2. Replacement Key
    By davidsucg in forum General Tech Discussion
    Last Post: 01-09-2010, 12:13 AM
  3. LIM replacement
    By mikesarebetter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-24-2009, 04:32 PM
  4. Rad Replacement
    By GPSims39 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-11-2009, 09:22 AM
  5. 6x9 replacement
    By 99gpse in forum Audio, Security & Visual Electronics
    Last Post: 01-31-2009, 07:11 PM
