Thread: Clunk or grinding sound when shift into reverse
Results 1 to 20 of 21
  1. #1 Clunk or grinding sound when shift into reverse
    Oct 2012
    USA
    First, the car drives great and shifting is very smooth. But,
    When I had a cold start and shift into reverse, I can hear a grinding kind or clunk sound. It does this when the car is cold. When the car is warm, the grinding goes away but I still hear kind of a clunk. The clunk is much weaker though. I can only hear it inside the car. I try to listen the sound with the window open, I can hardly hear anything from outside. Also, when shift into reverse, I can feel a impact as if something in the front end hit the car and try to push it back. I can feel the same impact when shift into drive but the impact is much weaker. And there is no sound shifting into drive.
    I looked at the engine when shifting. When shifting to reverse, the engine moves a little bit. When shift into drive, engine does not move at all. When I put the car in park and give gas, the engine does not move at all. The car idles very smooth, no shake or vibration when I give gas.
    I am wondering if this is normal. I found people say that the reverse is not synchronized so it will be a little rough than shifting to drive. So I am just asking if this kind of thing is normal. Maybe I am just too paranoid.
    Thanks very much for your help!
  2. #2 Re: Clunk or grinding sound when shift into reverse
    A bad motor mount can cause the clunk.
  3. #3 Re: Clunk or grinding sound when shift into reverse
    Oct 2012
    USA
    Thanks! I was suspecting the motor mount. But the car is so smooth when I drove it and the engine does not move that much when I shift into reverse. Engine does not move when shift into drive. So I am not leaning towards a bad mount. But I will get it checked out soon.
    Also, the sound is like grinding when car is cold. I can also hear a slight grinding kind sound when shift out of reverse when the car is cold. When the car is warm, shifting out of reverse has no sound at all.
    So besides the sound, is the kind of impact I feel normal? Thanks!!!!
  4. #4 Re: Clunk or grinding sound when shift into reverse
    Fluid levels are correct right?
    Are you modded at all?
    A aftermarket intake can be produce a grind/shovels on concrete sound while cold and go away when the engine warms up a little.
  5. #5 Re: Clunk or grinding sound when shift into reverse
    Oct 2012
    USA
    Yes, I have checked the fluid level several times and it is correct. The transmission fluid and filter is changed by dropping the pan about 2k miles ago but the sound exist before changing the fluid. Transmission feels the same after changing fluid so I haven't doubt the fluid change.
    The car is completely stock. No modification. All parts in the car are OEM, except wiper blade......
    Just to clarify, the sound happens when I shift into reverse and no noise when I am moving either forward or backward. It is just sound when I shift. No sound when I am moving.
    Thanks a lot for your help!
  6. #6 Re: Clunk or grinding sound when shift into reverse
    The car is a 2005 Base model if anyone wanted to know, I looked at his profile.
    This grinding type sound you are hearing kinda has me stumped, but as for the "impact" feel that is somewhat normal. You are suppose to be able feel it a little bit when you go between the gears. I know I can always feel it when I go into reverse, then from R to Drive. You get that small push type feel as it grabs the gear with your foot on the brake. Seems to grab harder in reverse when really cold because the fluid is not warm.
  7. #7 Re: Clunk or grinding sound when shift into reverse
    Oct 2012
    USA
    Thanks a lot! I should include the car model in the initial post. It is a 2005 Pontiac Grand Prix Base model with 90000 miles now. The car is completely stock without any modification.
    You are absolutely right. When I drive, I can feel the car changing gear. Since the impact is normal, I will not worry about it. It makes sense when the transmission grab gear and try to push the car forward or backward.
    The grinding kind of sound somehow makes me a little nervous. The magnitude of "impact" or "push feel" is pretty similar when the car is cold or warm. I cannot think of a reason how the grinding happens only when the fluid is cold. If fluid is cold and it is thicker, it should somehow provide more "cushion".
    Maybe it has something to do with the fluid flow or fluid pressure inside transmission?
    I live here. DirtDog's Avatar
    Jun 2012
    It sounds like what I was experiencing with my old 04 gp. Turned out it was the tranny mount and engine mounts. Their probably due for a change right about now
    Sent from my pager using Morse code. ... .. ... ....
  9. #9 Re: Clunk or grinding sound when shift into reverse
    Oct 2012
    USA
    Thanks! Hmmm....It seems like I should get the transmission and engine mount checked out first. How much does it cost you to replace the engine mount and transmission mount? Since my current situation does not affect my driving, I might just live with it if it is expensive.
    Jun 2012
    It depends on which mounts u go with...local auto parts store ones will be cheap but aren't very good...the poly mounts I highly recommend are about 60 I think
  11. #11 Re: Clunk or grinding sound when shift into reverse
    Aug 2012
    florida
    check drive shaft U joint cups
  12. #12 Re: Clunk or grinding sound when shift into reverse
    Quote Originally Posted by peter View Post
    really?
    GT Level Member iRideGTP's Avatar
    Jul 2012
    California
    Replaced tranny mount today and the clunk when reversing went away. Bought mount from Rockauto for less than $30
    Sent from my SGH-T679 using Tapatalk 2
  14. #14 Re: Clunk or grinding sound when shift into reverse
    Oct 2012
    USA
    Just following up my original post. I went to a local shop and the mechanic checked it today. They said it is due to "weak engine and tranny mount". The way they check is that they rev up the engine with brake pressed while shifting to D and R. They told me it is normal tear and wear to the rubber in the mount. The mounts are a little weak but they are still OK. They just get normal wear over time. I asked them if I need to change them. They say I am good to go. They can change it if I want but he suggest me not to do it now.
    Jul 2012
    California
    Just replace them. Top mounts might be fine but not lower mounts
  16. #16 Re: Clunk or grinding sound when shift into reverse
    Oct 2012
    USA
    Quote Originally Posted by iRideGTP View Post
    Thanks! I have two shops checking it and they both suggest no need to change now. Since I am a student and don't have much extra money, I guess I will just live with the initial clunk when it is cold. Since the car drives fine, I will just leave as it is now.
    Thanks very much for your advice!
  17. #17 Re: Clunk or grinding sound when shift into reverse
    Jun 2012
    now isnt that what i originally said it was
  18. #18 Re: Clunk or grinding sound when shift into reverse
    Oct 2012
    USA
    Haha, you are right! I should learn more about diagnosing car problems.
    Bunnell, FL
    Don't I feel dumb for going full poly for every mount
    I'm a Sex Offender
  20. #20 Re: Clunk or grinding sound when shift into reverse
    Aug 2012
    florida
    I was close with u jount cups
  1. Grinding sound when making sharp left and awful creak sound when going over bumps
    By rescuetoaster in forum Brakes/Suspension/Chassis
    Last Post: 03-04-2012, 10:06 PM
  2. Grinding noise in reverse, then no movement
    By chantspel in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2010, 08:08 AM
  3. grinding noise in reverse
    By wrathofthunder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 08:24 PM
  4. clunk going into reverse????
    By vader99 in forum General Tech Discussion
    Last Post: 01-20-2010, 07:44 PM
  5. Clunk from diff going into reverse
    By TZFBird in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-18-2009, 10:02 PM
