Thread: Clunk or grinding sound when shift into reverse
Results 1 to 20 of 21
  1. #1 Re: Clunk or grinding sound when shift into reverse
    Fluid levels are correct right?
    Are you modded at all?
    A aftermarket intake can be produce a grind/shovels on concrete sound while cold and go away when the engine warms up a little.
  2. #2 Re: Clunk or grinding sound when shift into reverse
    Oct 2012
    USA
    Yes, I have checked the fluid level several times and it is correct. The transmission fluid and filter is changed by dropping the pan about 2k miles ago but the sound exist before changing the fluid. Transmission feels the same after changing fluid so I haven't doubt the fluid change.
    The car is completely stock. No modification. All parts in the car are OEM, except wiper blade......
    Just to clarify, the sound happens when I shift into reverse and no noise when I am moving either forward or backward. It is just sound when I shift. No sound when I am moving.
    Thanks a lot for your help!
  1. Grinding sound when making sharp left and awful creak sound when going over bumps
    By rescuetoaster in forum Brakes/Suspension/Chassis
    Last Post: 03-04-2012, 10:06 PM
  2. Grinding noise in reverse, then no movement
    By chantspel in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2010, 08:08 AM
  3. grinding noise in reverse
    By wrathofthunder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 08:24 PM
  4. clunk going into reverse????
    By vader99 in forum General Tech Discussion
    Last Post: 01-20-2010, 07:44 PM
  5. Clunk from diff going into reverse
    By TZFBird in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-18-2009, 10:02 PM
