Lower ones, it's usually the engine mount (under the balancer area) and the trans mount on the drivers side. I'd bet if you leave the hood open and look at the motor when you shift into R or D you will see the engine move quite a bit. If the mounts are covered in a greasy goo, then they're done for.
