Thread: Trans Problems!!!
Results 1 to 5 of 5
  1. #1 Trans Problems!!!
    Apr 2009
    geary
    I have a 05 Grand Prix GTP with 217000kms on it.. The trans wont go into Drive... When Shifter is D or 3 Veh wont move... Put it in 1 and 2 and it moves but hesitates... Works perfect in Reverse... Dropped Pan fluid wasnt burnt and no unusual metal peieces in the Pan... Linkage is perfect.. Wondering if anyone had this problem before... Thinking maybe it might be Shift Solenoids.. All Info will help Thanks
    Adam
  2. #2 Re: Trans Problems!!!
    Foward band let go is my guess.
  3. #3 Re: Trans Problems!!!
    I second forward band
  4. #4 Re: Trans Problems!!!
    Apr 2009
    geary
    But I can Drive it when you put it in 1 or 2nd on the Shifter.. When you put it in park then the trans makes a funny noise...
  5. #5 Re: Trans Problems!!!
    But...........
    Read up on the forward band problem. You cant use D or 3 when it goes, but 1-2 and work because you are putting it into those gear manually.
    Wont move in D or 3 only
  1. Tc problems on built trans
    By RamonGTX in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2012, 06:05 AM
  2. Neverending trans problems
    By ls1camino in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-04-2012, 06:58 AM
  3. GTP Trans problems
    By kiefer316 in forum General Tech Discussion
    Last Post: 03-14-2011, 10:29 AM
  4. trans problems
    By carl612 in forum Forum Bugs/Suggestions
    Last Post: 07-31-2010, 09:03 PM
  5. Trans problems.
    By my97gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-07-2008, 07:24 AM
