Thread: shifting problems
Results 1 to 7 of 7
  1. #1 shifting problems
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    i have a 00 pontiac grand prix gtp and when i start the car and shift into reverse or drive it clunks very harshly. Then theres other times it does it smooth. Im confused what could be causing this. I have a 130k miles and i changed the tranny fluid at 100k. Anyone have any ideas? thanks
  2. #2 Re: shifting problems
    That is typicaly motor mounts. Give them a check over and let us know what you find.
  3. #3 Re: shifting problems
    the top motor mounts? or the lower one. I actually do have shorter dog bones but i cant tilt the engine back far enough to get the bolts through.. Do you guys have any tricks. i even tried to pry the engine forward with a 2x4 and that wasnt enough
  4. #4 Re: shifting problems
    St. Louis
    Lower ones, it's usually the engine mount (under the balancer area) and the trans mount on the drivers side. I'd bet if you leave the hood open and look at the motor when you shift into R or D you will see the engine move quite a bit. If the mounts are covered in a greasy goo, then they're done for.
  5. #5 Re: shifting problems
    how do i replace the lower engine/tranny mount. i dont have an engine hoist
  6. #6 Re: shifting problems
    GTP Level Member winterstorm's Avatar
    Jun 2012
    Connecticut
    wait a minute, did u say that you can bolt the engine into the dogbones? so those arent even attached to the engine?
    2005 Grand Prix GT
    Corsa Sport Catback, Thrasher Shift Kit, Custom Open Cone Intake, Spyder Chrome CCFL Halo Projector Headlights, CG LED Tail Lights, Pioneer DEH-33HD stereo unit, Alpine SPR-60C 2 way 6 1/2's, Kicker KS 6x9's
  7. #7 Re: shifting problems
    Apr 2011
    Vassar, Mi
    I would check the lower control arm bolts too. My car was clunking like crazy going from forward to reverse for the longest time and I could never figure out why, even after new wheel bearings, cv axles and building the trans it still made the same noise and it turned out to be a loose control arm bolt.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  1. Shifting Problems Misfiring Maybe
    By Numbah in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-25-2011, 07:47 AM
  2. Shifting Solenoid Problems. Please Help!
    By Hixc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-02-2011, 12:49 PM
  3. 2 to 3 tranny shifting & WOT shifting problems
    By josh in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-21-2010, 08:52 PM
  4. Shifting problems
    By at2smithjason in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-13-2010, 01:27 AM
  5. Shifting problems
    By bonnevillain in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-10-2009, 01:00 PM
