Thread: 04 GTP Trans Starting to slip
Results 1 to 20 of 23
  1. #1 04 GTP Trans Starting to slip
    Nov 2008
    Central NJ
    I started a thread last week regarding some noise I was having with my front end. I was suspecting front hub but after changing it and the noise not going away I'm not sure if that was the problem, so I started this thread for the trans trouble.
    I've got a '04 GTP with 115k miles. Everything is stock and don't normally abuse it since its my DD.
    Approx 2 weeks ago I was making a left turn out of my neighborhood and heard what sounded like a 'pop'. Right after that I heard what I though was my hub went bad because it sounded like excessive road noise. Not a grinding but could possibly be considered a whining. It also got louder with speed. I didn't have any issues with the trans at that time. I put the car in the garage and after a few days, changed out the front driver hub. Well the noise remains but there still wasn't any signs of trans trouble. After another 2 days of driving, I noticed that at startup from a full stop, the engine seemed to rev a lot higher than usual in 1st gear. I think it was going around 3500rpm before it would shift to 2nd. (This was under very light throttle) Later I noticed when I was cruising at 40mph the tach showed around 2000rpm so I'm not sure what gear I was in but I'm assuming 2nd or 3rd. Normally I'll cruise on the highway at 70mph and 2000rpm so something seemed wrong. After driving 15 minutes and everything warmed up nicely, the trans seemed to be working OK. When I was on the highway and cruising at 60+mph, I punched the gas a little and it downshifted like normal and as soon as I got off the gas, the rpms went right back to where they normally are on the highway.
    I've seen a bunch of posts where problems occur when the car is hot and not cold but I'm having just the opposite. I'm new to trans problems and don't have much knowledge on whats going on inside but I'd love to know what some possible causes are so if I have to go to a trans shop, I'm not standing there like some idiot with an open wallet and a note on my head that says take as much as you want.
    A little history:
    Bought car with 90k and put on 25k miles in 16 months
    I'm not sure if trans was ever serviced
    Fluid doesn't look very reddish. Possibly a little on the grey side(not black like dirty motor oil) and could probably use a filter and fluid change
    Fluid does not look low.
    Any suggestion are greatly appreciated.
  2. #2 Re: 04 GTP Trans Starting to slip
    Your trans is fine. You were in third gear. Most 2.93 gear ratio tables (the one in your car) shift out of third into fourth around 42-47mph.
    Had you gone a little faster, it would have shifted into 4th.
    Smile..you have a noise, but it's not trans. Likely it's the axle.
  3. #3 Re: 04 GTP Trans Starting to slip
    Nov 2008
    Central NJ
    I drive this road everyday going 40mph and I never remember the rpms quite that high. I could hear the engine was revving higher than usual and that's what caught my eye.
    What about it going up to 3500rpm before it shifted to 2nd gear? It was under light throttle and normally it would have shifted before it got to 3000rpm. I forgot to mention that when it went up to 3500rpm it just seemed to hang up there and not shift right away. I didn't want it to slam into 2nd gear so I got off the gas and got on the gas lightly and then it shifted into 2nd.
  4. #4 Re: 04 GTP Trans Starting to slip
    Tough to say. I believe 3000-3500 is about normal from first to second. I don't anally obsess over mine that often and would just look at the table in the tuner. Which I or someone where could do for you. I can't do it now, but could later on.. maybe I'll even look up that cluster thing Monkey Breath was asking about.
    A pop from a transmission isn't typically going to cause what you are talking about for issues. A pop from a trans is going to quickly show it's ugliness and you'd know you had trans issues.
    To sum it up. I believe you are over sensitive toward it at the moment.
  5. #5 Re: 04 GTP Trans Starting to slip
    Nov 2008
    Central NJ
    Took my GTP to AAMCO to check it out and according to them, I have no 2nd gear and to rebuild it would be at least $2,211 and then whatever parts they would need to fix would be additional. Anybody know a good place to get a used 04 GTP Tranny in NJ?
  6. #6 Re: 04 GTP Trans Starting to slip
    Nov 2008
    Central NJ
    I haven't done anything with my tranny yet except for making some calls and pricing things out. I found a used trans with 94k on it for $550 and 90 day warranty. I was debating on swapping it myself but it's definitely the biggest repair I've tackled myself. I also found a shop that said they could do the swap for $460. Do these numbers sound good? From what I've seen, they're probably the cheapest I think I'm going to find.
  7. #7 Re: 04 GTP Trans Starting to slip
    thats not to bad really, the trans is a bit on the high side, but its got a warranty, so that piece of mind makes up for the price.
  8. #8 Re: 04 GTP Trans Starting to slip
    Nov 2008
    Central NJ
    Thanks. I know for a normal trans it would be a little high but since it's for a GTP a thought it was a pretty good price.
  9. #9 Re: 04 GTP Trans Starting to slip
    i ve seen em on craigslist for 400. but no warranty. and its a random seller.
    sounds like your buying it from a shop or yard.
    anything under 500 for the install is a good price as well.
    i would drop the pan and change the filter, if thats not in the plans.
  10. #10 Re: 04 GTP Trans Starting to slip
    Nov 2008
    Central NJ
    I was definitely going to do the filter since the used trans is coming from a junk yard. I'd be able to change the filter while it's off the car...right? This way I can take care of it before the shop does it and has to charge for it.
  11. #11 Re: 04 GTP Trans Starting to slip
    Nov 2008
    Central NJ
    Oh I forgot. I'll probably also get a hold of a new trans mount so the shop can throw it in while the trans is out.
  12. #12 Re: 04 GTP Trans Starting to slip
    Kansas
    Like Scotty said, also throw a bottle of Lucas Tranny Stop Slip.
  13. #13 Re: 04 GTP Trans Starting to slip
    its easier to drop the pan when its in the car. so if you do it or the shop does it, it really dont matter, as long as it gets done.
    and to be honest, id make sure it moves before putting 50 bucks more into it. if it drives, shifts, and it seems to be working well, then do the fluid and filter. if the trans is bad, you've just wasted 50 in new fluid and the filter.
    trans mount would be a good idea too.
  14. #14 Re: 04 GTP Trans Starting to slip
    Nov 2008
    Central NJ
    Good point. I didn't think of that.
    Thanks
  15. #15 Re: 04 GTP Trans Starting to slip
    Nov 2008
    Central NJ
    I was just playing out the whole process in my head this morning on the way to work and then I hit a small bump in the road. Won't I have to put fluid in the replacement tranny before I can test drive it to see if everything is working correctly? Seems like a "catch 22". I don't want to waste the $$ on fluid if the tranny is bad but I can test it without spending $$ on the fluid. Am I missing something? Should I reuse the old fluid just for a quick test run?
  16. #16 Re: 04 GTP Trans Starting to slip
    that all depends on weather or not they drained the tranny. junk yards dont always drain stuff. you need to check the level of the fluid and go from there. color, smell.
    the old fluid tells a lot about the trannys condition. i would think they would leave the old fluid in there.
  17. #17 Re: 04 GTP Trans Starting to slip
    Just read that myself. filter is $10 by itself. have it done..filled and off you go.
  18. #18 Re: 04 GTP Trans Starting to slip
    GTP Level Member AjL227's Avatar
    IL
    I would just change/refill the fluid and replace the filter in the junkyard trans before you attempt to drive it.
    This may be a bad time to say but...I'm in the middle of the changing out the original trans in my car at 80k.
    I got a junkyard tapshift trans with a rebuild date stamped 6/15/11 on it for $250 with the engine.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  19. #19 Re: 04 GTP Trans Starting to slip
    Nov 2008
    Central NJ
    I just called around on Friday to see if I could track down a better deal on a used trans. I found a closer junk yard that could get one for me with only 68k miles instead of the 100k trans I was going to get. What makes the deal better was it also cost less. Only $475 for this one compared to $600 for the other one. At least this will have only half the miles my car currently has(115k).
    Good luck on your swap. I'm sure I'll be checking this forum a lot while I'm working on my swap. I already ran into my first problem. My passenger side axle has NO visible threads on the exposed section of the axle. They were completely rusted and after hitting it with a wire brush, the threads are now completely gone. It looks like I'll be taking the axle off along with the hub and lower control arm as one complete part. Hopefully this isn't a sign as to how the rest of this swap will go.
  20. #20 Re: 04 GTP Trans Starting to slip
    Bandit..try undoing it. You might only need a new axle.
  1. 4t65e slip?
    By IntenseFace in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-12-2012, 10:28 AM
  2. How much slip is ok?
    By fri3dchick3n in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-02-2012, 02:00 PM
  3. Belt slip
    By TTalon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2011, 02:30 AM
  4. tcs and trans slip???
    By Justin48 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2010, 09:06 AM
  5. trans whine/squeal + shudder&slip
    By almighty in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-20-2009, 10:00 AM
