Thread: Get a Rebuild transmission or a used one from a junk yard
Results 1 to 17 of 17
  1. #1 Get a Rebuild transmission or a used one from a junk yard
    Alright I have a 97 Grand Prix Gt and 2 weeks ago my decide to stop working. my transmission will go cycle throught all the gears but it won't go anywhere like it will go to like 25mph but after it goes that fast it cuts out and stops going and then all then all the car does then is revs. Also at 15mph the rpms is at 3000 in which i thought it is not good when going that slow and the rpm is that high. I'm either thinking about selling it for parts or just get the transmission rebuild for $990 which i dont have the money for it right now so ill have to save for a which now or get a used one from a junk yard from a another grand prix. What do you guys think happened to my transmission? what should I do guys?
  2. #2 Re: Get a Rebuild transmission or a used one from a junk yard
    new britain, ct
    IMO get a new (used) transmission. except get a whole 4t65 transmission. in 97, your car came with a particularly weak transmission (the 4t60), and 98+ came with 4t65's.
    07 Black GXP.
  3. #3 Re: Get a Rebuild transmission or a used one from a junk yard
    Mar 2012
    NC
    4T60 wasn't a great trans, but it worked. Finding one may prove difficult as it is a 2 year only trans for that car...1996 Regal will work and 1997 Grand Prix GT are the only fitments.
  4. #4 Re: Get a Rebuild transmission or a used one from a junk yard
    Mar 2012
    NC
    Ok...after further research, it's an easy trans to find on car-part.com. They're going for about $150 with 100k.
  5. #5 Re: Get a Rebuild transmission or a used one from a junk yard
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Id agree with ctracer and as long as your gonna be pulling it id swap it out and go with the 4t65 or 4t65-hd if you can get one from a GTP it will be the 4t65-HD
  6. #6 Re: Get a Rebuild transmission or a used one from a junk yard
    So u guys think i should go find a used 4t65 trans. or get one from a 1996 Regal i am kinda confused on what you guys are saying well this is my car is my first car so bare with me
  7. #7 Re: Get a Rebuild transmission or a used one from a junk yard
    mine isnt super charged yet
  8. #8 Re: Get a Rebuild transmission or a used one from a junk yard
    Mar 2012
    NC
    Garry, the trans you currently have came in two cars only...the 1997 Grand Prix GT or the 1996 Buick Regal. It is a 4T60e. Just buy another one with a warranty and slap it in. Problem solved.
  9. #9 Re: Get a Rebuild transmission or a used one from a junk yard
    Jan 2012
    Indianapolis
    I wouldn't get another 4T60 which is what youll get out of a 96 Regal. Get one that is a 4T65 or 4T65-HD the hd will work even if your not sc
  10. #10 Re: Get a Rebuild transmission or a used one from a junk yard
    Mar 2012
    NC
    The problem with switching to the 4T65e is the harness is different and he'll need a PCM because unfortunately you can't tune a 4T65 into the 97 GT. This is the reason I say stick with the 4T60e.
  11. #11 Re: Get a Rebuild transmission or a used one from a junk yard
    Quote Originally Posted by indygrandprix View Post
    the Hd has different gears, so the pcm would need to be reprogrammed
  12. #12 Re: Get a Rebuild transmission or a used one from a junk yard
    What's the difference between the 4T60 and the 4T65 and the 4T65-HD?
  13. #13 Re: Get a Rebuild transmission or a used one from a junk yard
    Mar 2012
    NC
    4T60e uses a vacuum modulator to control transmission pressure and uses a weak transmission pump. The 4T65e uses a solenoid to control transmission pressure and is completely electrically controlled.
  14. #14 Re: Get a Rebuild transmission or a used one from a junk yard
    new britain, ct
    if you can find a 4t60e for cheap...get it.
    07 Black GXP.
  15. #15 Re: Get a Rebuild transmission or a used one from a junk yard
    the easy thing to do is to put back what you take out, over done.
  16. #16 Re: Get a Rebuild transmission or a used one from a junk yard
    I almost forgot that my trans fluid was brown when i drained it
  17. #17 Re: Get a Rebuild transmission or a used one from a junk yard
    Mar 2012
    NC
    That's what I've been saying. lol
  1. Junk yard find!
    By mkyota1 in forum General Grand Prix Discussion
    Last Post: 05-13-2012, 11:57 AM
  2. 97 gtp in the junk yard
    By ibhuff in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2011, 06:51 PM
  3. Junk Yard Laughs
    By InfidelRebel in forum Off Topic Discussion
    Last Post: 08-25-2009, 05:38 PM
  4. I love the junk yard
    By Mad Monkey in forum Audio, Security & Visual Electronics
    Last Post: 07-22-2009, 01:01 PM
