Thread: trans jerks after stop
Results 1 to 16 of 16
  1. #1 trans jerks after stop
    SE Level Member grey08's Avatar
    Jun 2012
    cleveland ohio
    just bought a 08 gp and my trans jerks after a stop only happend a couple times and dont know what it could be?
  2. #2 Re: trans jerks after stop
    Jun 2012
    cleveland ohio
    Quote Originally Posted by grey08 View Post
    Any body have a idea no codes 91 000 miles plZ help
    Dec 2010
    DMV
    Have you checked the fluid? Color of the fluid? Last time it was serviced? Fluid levels correct?
  4. #4 Re: trans jerks after stop
    GT Level Member GMCustomerService's Avatar
    Michigan
    The slip yoke splines may need to be cleaned/lubricated or replaced. This is just a suggestion, not a diagnosis. I encourage you to consult with a certified technician for an official diagnosis.
    Please keep us posted.
    Louis
    GM Customer Service
    Check out the NEW Owner Center at: My.GM.com
  5. #5 Re: trans jerks after stop
    Quote Originally Posted by GMCustomerService View Post
    Louis
    GM Customer Service
    what slip yokes are you referring to? this is a fwd car.
    rwd cars have slip yokes on the rear and front drive shafts, if a 4x4. when they get dry its referred to as brake squawk, its a GM tsa.
  6. #6 Re: trans jerks after stop
    Michigan
    My apologies. Posted on the wrong forum. Thankfully the weekend is almost here!
    Louis
    GM Customer Service
  7. #7 Re: trans jerks after stop
    Jun 2012
    cleveland ohio
    pulled pan and changed filter and fluid still dont feel right everything looked normal as far as what was in the pan. fluid was not that bad either
  8. #8 Re: trans jerks after stop
    Only thing I can think of is a delays downshift to 1st. But that doesn't even make any sense.
  9. #9 Re: trans jerks after stop
    Apr 2009
    Fort Worth TX
    Could he be experiencing some engine surge due to a bad check valve in the master cylinder vacuum line?
  10. #10 Re: trans jerks after stop
    Or iac being a little sticky on picking up from the decel...sure. We are kinda stretching though.
  11. #11 Re: trans jerks after stop
    Apr 2009
    Fort Worth TX
    Easy way to tell if it's the master vacuum is pump the breaks hard while going slow.
    I request a better description of what is actually happening.
    "jerks after stop"
    Not very informative.
  12. #12 Re: trans jerks after stop
    Although not super descriptive... I think I understand what is being said. I want to say that's the first releasing or second dropping to first.
  13. #13 Re: trans jerks after stop
    Apr 2009
    Fort Worth TX
    Bill
    Wouldn't that just cause the engine to bog a little?..a late second to first down shift?
  14. #14 Re: trans jerks after stop
    I don't think so.. Maybe a sticky soleniod or check ball.. I'd have to read up on that link I posted to the trans/info links thread by me yesterday. BTW.. Seriously good info there.
  15. #15 Re: trans jerks after stop
    Jun 2012
    cleveland ohio
    the only thing i can think of is a solenoid or something to do with the line pressue not enough?
  16. #16 Re: trans jerks after stop
    Donating Users Tengis's Avatar
    Houston
    I think Ive got the same issue with my daily driver. I suspect something physical like an axle with my clunking.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  1. My car jerks at 4000 RPM/ Shuts off when I reverse
    By metalexa1 in forum Introductions/Noob Questions
    Last Post: 06-08-2012, 03:26 PM
  2. 4T65E Trans behavor when accelerate from stop
    By wcarrothers in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-28-2010, 02:13 PM
  3. trans issue from stop or slow speeds
    By bryan795 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-29-2010, 12:43 PM
  4. NEED HELP: Speedometer malfunction and car jerks
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-11-2010, 08:39 PM
  5. jerks when shifting
    By kenneth74gt in forum General Tech Discussion
    Last Post: 01-04-2009, 01:23 PM
