1097 and 3366 are the radiator side of the cooler lines.
958 and 677 are likely one supply and one return. I was talking about the supply with the checkball only. You are getting pretty technical and that's good for knowledge/sharing etc. However if you go see your dealer with your vin, he's going to supply you with a single part number for supply and a single for return that screw into the transmission. Which likely correspond to 958 and 677 or a superceding part number for each.
Actually..if you'd be willing to post your VIN, we can have dealership guy TLSheff run it and give you the correct part for the car.
Wouldn't his computer just pull up the 1st design parts?
