Thread: no overdrive, pump whine, slips in first
Results 1 to 6 of 6
  1. #1 no overdrive, pump whine, slips in first
    Jul 2012
    lanse, mi
    upon a rescent roadtrip i noticed my car lost od and i noticed a whine coming from the front if i exceed 45 mph. also the past couple days it has slipped upon take off a few times and its not throwning any codes... checked fluid which looked good except there was some bubbles on the stick... what i am wondering is should i pull the side cover and try replaceing the shift and tcc solenoids or should i not waste the money and just find a used transmission.
  2. #2 Re: no overdrive, pump whine, slips in first
    May 2012
    Burlington, Wisconsin
    Whine could be coming from the power steerings. I have a whine and I'm almost positive that's what it is.
    1998 GTP Sedan: Gen III, Speedy Daddy Headers, SLP Catback, Magnaflow High Flow Cat, Open Cone Intake, Autolite 104s, Debadged, more to come!
  3. #3 Re: no overdrive, pump whine, slips in first
    depending on the miles you have, it may be best to get another trans.
    4 th gear burns out in the older models.
    and if its slipping, its on it way to its grave.
  4. #4 Re: no overdrive, pump whine, slips in first
    GT Level Member Utter99's Avatar
    Warsaw indiana
    if you have a 97gtp i have a transmision waiting for you..
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  5. #5 Re: no overdrive, pump whine, slips in first
    You could change the fluid and filter and get a little more life out of it but it's probably on it's way to the scrapyard.
  6. #6 Re: no overdrive, pump whine, slips in first
    Whine from a trans is typically the pump not getting enough fluid. This will also cause slip, because trans is basically a big conglomeration of hydraulics.
    The bubbles is often a bad channel plate gasket, which would let pressure bleed off and cause the issues you are mentioning. This gasket can be fixed along with the overdriver hub shaft (aka 4th clutch hub) by removing the side cover. It's tough to say w/o pressure testing etc, but it's very likely the gasket went.
    If I were going in to fix this, I'd change the channel plate gaskets, epc/pcs (same part) and the 4th hub shaft all at the same time.
  1. overdrive
    By BOOSTED GP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-09-2011, 12:03 PM
  2. On-and-off overdrive...
    By Hogrydr in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-22-2010, 11:32 PM
  3. '98 WON'T go into OVERDRIVE
    By jdkopveiler in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-01-2009, 11:52 AM
  4. Fuel pump whine when engine gets hot
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-02-2009, 02:23 PM
  5. No overdrive
    By 99prixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-16-2009, 02:31 AM
