Thread: converting tranny cooler lines from 1st design to 2nd design
Results 1 to 20 of 26
  1. #1 converting tranny cooler lines from 1st design to 2nd design
    Dec 2011
    Hagerstown, MD
    Is this possible? I've read that all you have to do is change the fittings on the rad and tranny cooler inlets/outlets, and then you could use the 2nd design lines. However, that was from one source and no one verified it. 04 impy with the 4t65e-hd. Built in january of 04 so it has the 1st design lines currently.
    Thanks.
  2. #2 Re: converting tranny cooler lines from 1st design to 2nd design
    Dec 2011
    Hagerstown, MD
    TEP informed me the lines are teh same between designs, and that the only difference is the threaded connectors? Odd, but I'lll have to get eth 2nd design connectors I guess and be happy with life.
  3. #3 Re: converting tranny cooler lines from 1st design to 2nd design
    yeah..unsure what other design you think you have. I've seen three versions of lines.
    97 threaded at both radiator and trans
    98 threaded at trans and click at radiator
    99+ Click at both radiator and trans.
  4. #4 Re: converting tranny cooler lines from 1st design to 2nd design
    Dec 2011
    Hagerstown, MD
    For example, look at part#s 15264589/15264588, and 20793004/20793005 on rockauto (this shows up on other sites too). An eample for teh 20793004: description says "HOSE,TRANS FLUID CLR INL 1ST DESIGN; USE ON VEH BUILT PRIOR TO 2/1/04-2ND DES 15264588" etc..
  5. #5 Re: converting tranny cooler lines from 1st design to 2nd design
    Portland Oregon
    There are two different "designs" Bill. I've got an 04 GTP and when I had to order a cooler line the dealer asked me if it was the first or second design. I ended up giving them my VIN and since my 04 was built in 03 it had the first design lines. Sometime in 04 there was a switch of some sort.
  6. #6 Re: converting tranny cooler lines from 1st design to 2nd design
    Dec 2011
    Hagerstown, MD
    Quote Originally Posted by OH4CompG View Post
    Which was 2/1/04 as far as I can tell, so that's why i'm just trying to find out if it's just the fittings that are different and can be swapped or if there is something more involved.
  7. #7 Re: converting tranny cooler lines from 1st design to 2nd design
    Portland Oregon
    Pretty sure it's just the fittings. Don't quote me though, I have no idea if they're interchangeable
  8. #8 Re: converting tranny cooler lines from 1st design to 2nd design
    Dec 2011
    Hagerstown, MD
    Gotcha. This has certainly been one of the few times that google has failed me lol.
  9. #9 Re: converting tranny cooler lines from 1st design to 2nd design
    I had something similar trying to do the lines on my 97 Bonneville. It was all about the production date and in my case it came down to some small revision in the lines..like an extra 3/8" in length that had no effect overall.
  10. #10 Re: converting tranny cooler lines from 1st design to 2nd design
    I thought there was an internal/external check ball which meant they can't be swapped.
  11. #11 Re: converting tranny cooler lines from 1st design to 2nd design
    In the non-checkball fittings, the ball was in the valve body instead of in the fitting.
  12. #12 Re: converting tranny cooler lines from 1st design to 2nd design
    Dec 2011
    Hagerstown, MD
    So 99+ fittings all havce the checkball, regardless of what design they are as long as they're quick-connect types?
  13. #13 Re: converting tranny cooler lines from 1st design to 2nd design
    To my knowledge....The click lines have the check ball in the fitting. Threaded don't.
  14. #14 Re: converting tranny cooler lines from 1st design to 2nd design
    Far as I can tell. GM only made one part number for that fitting that I can find. therefore if it's a clicker...one of the fittings has the checkerball in it.
  15. #15 Re: converting tranny cooler lines from 1st design to 2nd design
    Dec 2011
    Hagerstown, MD
    Are you sure there's only one? There's 4 different ones on rockauto :|
    Then there's 4 different part numbers for the threaded connectors for '1st design' ( 24213958, 19125677, 24233366, 52481097 ) and '2nd design' ( 24236555, 24229978, 24236554 )
  16. #16 Re: converting tranny cooler lines from 1st design to 2nd design
    Portland Oregon
    It's the cooler feed line that has the checkball in it.
  17. #17 Re: converting tranny cooler lines from 1st design to 2nd design
    1097 and 3366 are the radiator side of the cooler lines.
    958 and 677 are likely one supply and one return. I was talking about the supply with the checkball only. You are getting pretty technical and that's good for knowledge/sharing etc. However if you go see your dealer with your vin, he's going to supply you with a single part number for supply and a single for return that screw into the transmission. Which likely correspond to 958 and 677 or a superceding part number for each.
    Actually..if you'd be willing to post your VIN, we can have dealership guy TLSheff run it and give you the correct part for the car.
  18. #18 Re: converting tranny cooler lines from 1st design to 2nd design
    Dec 2011
    Hagerstown, MD
    Wouldn't his computer just pull up the 1st design parts?
  19. #19 Re: converting tranny cooler lines from 1st design to 2nd design
    I live here. TLSheff's Avatar
    Ok, because I'm just awesome at my job... I figured it out.
    Not Do-Able.
    At least not EASILY Do-Able. It is early still for me, and I'm having a off day so maybe I am reading the bulletins wrong. I am posting them, in case I am... but it looks to me the fittings are a different size so you would have to change the tanks/radiator/get an adapter? I'm sure there is something that can be done, but your call. If you need more help on this, just let me know.
  20. #20 Re: converting tranny cooler lines from 1st design to 2nd design
  1. Belt Question, 1st design or 2nd design?
    By 98GPGT2D in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2012, 01:10 PM
  2. 1st Design or 2nd Design Water Pump?
    By BlackGT1 in forum General Tech Discussion
    Last Post: 04-22-2012, 11:16 PM
  3. Cam design
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2012, 05:26 PM
  4. Tranny lines for trans cooler
    By monsterjam5000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-12-2010, 04:09 PM
  5. SRT Design
    By flash527 in forum Track Sessions and Kills
    Last Post: 07-22-2009, 06:27 AM
