Thread: Couple of Codes after Tranny install. Hmmm
Results 1 to 3 of 3
  1. #1 Couple of Codes after Tranny install. Hmmm
    GT Level Member Brian99SE's Avatar
    Dec 2011
    Cadiz, Ky
    So, As some have seen. My old transmission bit the dust. I put another one in, It was a freebie we that we had at the shop out of a 98 Buick Park avenue. Car was flood damage.
    Engine was used in another car with no problems. So I used the transmission with a new torque converter, Filter and fluids. It had a little water in the transmission which worried me but it was worth a shot. Transmission had been sitting out for a year.
    There was no issues at first, Scanned it and i get a handful of codes, I cleared them earlier and they have yet to come back on but I do not know if they will or not, Or if it was just some fluke codes from it sitting with a little water in it.
    P0140 (Existing)O2 Sensor Circuit Malfunction Bank 1 Sensor 2
    P0443 (Existing Never could figure out the issue) Evaporative Emission (EVAP) Purge Solenoid Control Circuit
    New codes
    P0716 input turbine speed sensor.
    P0717 Turbine Speed Sensor Circuit No Signal
    P0730 Incorrect Gear Ratio
    P1810 automatic transmission fluid pressure Valve Position Switch
    99 Grand Prix SE-Blue CAI, 3.03 GR Transmission, U Bend Delete.
    time to call the exterminator
  2. #2 Re: Couple of Codes after Tranny install. Hmmm
    Dec 2011
    Cadiz, Ky
    Hey Bill, Transmission that was in it had a 911 on the top of the case, New one has 906X i believe
    So If my research serves me correctly, My grand prix came with 3.29 gears, The Park Avenue transmission has a 3.05 gear ratio. Do I need to hook up to a Tech2 and change anything? Or do a Case learn?
  3. #3 Re: Couple of Codes after Tranny install. Hmmm
    Dec 2011
    Cadiz, Ky
    So No one ever replied. But I thought Id update. after driving about 1000 miles, It stopped throwing codes and started shifting better.
    0-90 run. Had a slight misfire from cylinder 1, Bad plug wire. Fixed now. can tell a difference with the 3.03 gears.
  1. Trouble codes after header install
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2011, 04:13 PM
  2. new motor in now have a couple codes
    By grn97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-16-2011, 03:06 PM
  3. SS intercooler and header install = engine codes
    By rascal in forum General Tech Discussion
    Last Post: 09-01-2009, 08:41 PM
  4. Tranny Stopped working today. Couple ??'s
    By fergup in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-04-2008, 11:56 AM
  5. Couple of cam install links
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2008, 08:56 AM
