Thread: Broken Trans Melting Engine?
Results 1 to 19 of 19
  1. #1 Re: Broken Trans Melting Engine?
    Jason..take another look. It's the Cali emission air injection actuator.
  2. #2 Re: Broken Trans Melting Engine?
    SE Level Member NiceHotRod's Avatar
    Apr 2012
    Upstate NY
    Thanks man now i know what that part is called. It needs to visually be on the car in NY since it's factory emissions equipment... if it doesn't work and doesn't cause a Check Engine light than it should pass inspection just fine.
    I've been away for work the last few days so I asked my local mechanic to diagnose the cat, and he thinks it's bad along with the O2 sensor. While this is much cheaper than a transmission, he did quote a very high repair cost. I'll let him know I can weld in a generic cat and replace both 02s myself for about $200.
    NiceHotRod
    02 Grand Prix GT 130k - Stock except for the red air filter
  3. #3 Re: Broken Trans Melting Engine?
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by NiceHotRod View Post
    I find it very odd that the secondary air injection system is melted and there is no DTC (P0410)
  1. coolant elbow broken inside engine
    By bjlandt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2013, 09:18 AM
  2. Broken plug, threads only - remove head or pull engine?
    By fearnot in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-02-2011, 09:54 AM
  3. melting hot hid
    By mik01gtp in forum General Tech Discussion
    Last Post: 07-24-2011, 10:57 PM
  4. Melting wires........
    By jlbrock1984 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2009, 11:08 PM
