Thread: Trans slips when trying to pass...
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
  1. #1 Trans slips when trying to pass...
    Donating Users LS2 BLAZER's Avatar
    Lorain, OH
    ok everyone, 2001 GP GT 125,xxx miles on her... been in the family since she had 3 miles on her...
    i recently took it off my moms hands for a DD since i have a TBSS as my toy... one thing i notice, while driving normally, the car shifts perffectly fine.. no issues, no slipping, nada.... but if i try to floor it, like say trying to merge onto a highway on the on ramp, or trying to pass someone on the street, the tranny starts slipping.. it will stay in the power band right up until the shift point, but when i goes to shift... vrrrrooooommmmmm it just sits and doesnt shift.. but this is only when trying to pass or "goose" it.. if i let off the gas once it slips, and the rpm's drop, it will shift into the next gear... again, while driving normally, keeping the rpm's between 3-4k, it will shift fine...
    any ideas on what could be going on??
    2001 Grand Prix GT - stock (for now )
    2007 Trailblazer SS - back under the knife , motor #4 on the way
  2. #2 Re: Trans slips when trying to pass...
    try a pan drop and filter change and add a bottle of lucas trans stuff.
    Lorain, OH
    Does it matter that one was done 25k miles ago? Kinda was included in a 100k matinenace package at the dealership at the time
    sent from my Galaxy S Epic 4G using Tapatalk
  4. #4 Re: Trans slips when trying to pass...
    Did they flush it or just do a pan drop? If it was flushed that's not to good on it but i can't see it being a problem 25K miles later. Check your fluid it could be a little bit low.
    Lorain, OH
    The did a flush and filter change, so yes a pan drop as well... fluids are ok as I jus got my oil changed last week.. no visual leaks either.. do these trannies have a passing gear in them?
  6. #6 Re: Trans slips when trying to pass...
    Not sure what you mean by passing gear. Your trans should downshift to pass. I'd put a bottle of lucas in it with a fluid and filter change. It's supposed to be done every 30K anyway so your getting close.
    Lorain, OH
    Yes it downshifts, but then when it goes to shift to the next gear, it slips... but only under stress..
    And 30k miles for a stock gp gt tranny service? That's odd... but its a starting point and cheap enough to give it a shot.. if the tranny goes, I might as well junk the car.. the price of a tranny and install would out weigh my efforts to keep the car
  8. #8 Re: Trans slips when trying to pass...
    St. Louis
    Is the slipping when it tries to shift from 3rd to OD? If so then I fear you are slowly loosing OD. The splines on the end of the shaft that engages OD is not hardened and as time goes on they wear down and eventually won't engage the 4th clutch hub. Then you will be running about 2500 or so at 60mph. I drove my 00GT this way for at least 2 years before I replaced the trans. and it was still shifting fine, except no OD.
    Lorain, OH
    Quote Originally Posted by FordMan77 View Post
    Thx for the input.. I don't think that's what's happening... when the TC is locked and I'm at cruising speed (say 65 mph) and I go and try to pass someone or "drop the hammer" as they say, on the gas pedel, the TC will unlock (downshift I guess you could call it) then the car will pull, but at the top of the power band, right before it goes to shift into the next gear (mind you, my foot is still to the floor), boom.. no shifting... while driving normally, it will shift perfectly fine... and at cruising speed (65 or higher) it is fine.. I just took her for a 6 hour drive accross state last month and got 28.2 mpg's and I believe the rpm's were at or under 2000.. so I don't think its OD... but I could be mistaken, I am very unfamiliar with these trannies.. I'm used to my 4L70e's and newer lol...
  10. #10 Re: Trans slips when trying to pass...
    Could be as simple as cleaning the maf and checking the TPS. Might be an issue in the trans. If you hit if from a stop, does it have trouble shifting from 1st to 2nd?
    If you are at highway speeds, heading uphill and give it some throttle w/o downshifting, does it slip? Does it slip if it's at any other throttle other than wide open?
    Lorain, OH
    Yes the issue is there from first to second from a stop if I goose it, but at half throttle to quarter throttle (when rpm's stay between 3-4000 rpm) the tranny shifts fine...
    And no it doesn't slip w/o downshifting....at quarter throttle and sometimes even half throttle there is no slipping either.. but foot to the floor or almost foot to the floor, she slips everytime...
  12. #12 Re: Trans slips when trying to pass...
    Do you feel it slip in the gear at wide open or just doesn't seem to shift?
    Slipping in gear may be input piston etc or clutches, at the shift.. like it just won't shift may be more electronic.
    Lorain, OH
    At wide open, there is no shifting at all... it just sits and revs between 4000-4800 rpm's with a ticking sound... once I left off the gas, it shifts...
    I made 3 videos, one of normal driving and shifting, one of normal driving, then punch it and it won't shift, then one from a stop to WOT and it won't shift.. they are uploading to youtub right now, so I'll post when they're done
    Lorain, OH
    Here's the vids... now what do you all think? If this is electrical, would a scanner work for error codes or diagnostics?
    https://www.youtube.com/watch?v=JbxV...e_gdata_player
    https://www.youtube.com/watch?v=xXrr...e_gdata_player
  15. #15 Re: Trans slips when trying to pass...
    Says videos are private.
    Lorain, OH
    Opps... ok I fixed it.. thx for lettin me know...
  17. #17 Re: Trans slips when trying to pass...
    That is definitely slipping. I'd do a pan drop and filter change with a bottle of lucas stop slip.
  18. #18 Re: Trans slips when trying to pass...
    Minnesota
    Suggestions:
    PCS Pressure control solenoid
    Bad torque converter??
  19. #19 Re: Trans slips when trying to pass...
    Lorain, OH
    Quote Originally Posted by Pure2sin View Post
    Suggestions:
    where is this PCS located and how can it be diagnosed? And obviously i would have to drop the tranny to get the TC.. im just looking for a cost effective way on this for now.... hopefully its not looking like i need a new tranny...
  20. #20 Re: Trans slips when trying to pass...
    Feb 2009
    flintnasty MI
    I would have to say that is not a transmission issue.... Most likely a misfire etc, because it should have revved out to 5500 rpms and about 40mph in first gear when flooring it. If it never gets to 5500 it wont try to shift, and it wont make "slipping trans misfires noise".
  1. 98 GTP, Trans lossing 4th gear sometimes, shifts hard and slips into 3rd.
    By shawnooohhh in forum General Tech Discussion
    Last Post: 02-11-2012, 10:44 AM
  2. 06 trans slips at 70mph or above
    By walk76z in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-17-2012, 08:17 AM
  3. Trans Slips Between shift when in normal
    By shawnschuldt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-16-2011, 09:25 AM
  4. trans slips only the first drive per day
    By shawnheck03gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-28-2010, 09:49 PM
  5. trans slips off the line when warm
    By beezer34ca in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-21-2010, 11:00 PM
