Thread: Epic Hail Mary 4T65 Build
Results 1 to 14 of 14
2003 SSEi Epic Hail Mary 4T65 Build 04-13-2012, 10:32 AM
2003 SSEi Re: Epic Hail Mary 4T65 Build 04-13-2012, 10:32 AM
matt5112 Re: Epic Hail Mary 4T65 Build 04-13-2012, 11:06 AM
Kejross Re: Epic Hail Mary 4T65 Build 04-13-2012, 11:06 AM
SlowNA06 Re: Epic Hail Mary 4T65 Build 04-13-2012, 11:23 AM
dazedandconfused ^^ This Sent from my... 04-13-2012, 12:21 PM
blueguy Re: Epic Hail Mary 4T65 Build 04-13-2012, 12:35 PM
BillBoost37 Re: Epic Hail Mary 4T65 Build 04-13-2012, 12:37 PM
gmpowered Re: Epic Hail Mary 4T65 Build 04-13-2012, 01:06 PM
BillBoost37 Re: Epic Hail Mary 4T65 Build 04-13-2012, 01:09 PM
SlowNA06 Re: Epic Hail Mary 4T65 Build 04-13-2012, 01:40 PM
BillBoost37 Re: Epic Hail Mary 4T65 Build 04-13-2012, 01:58 PM
2003 SSEi Re: Epic Hail Mary 4T65 Build 04-13-2012, 05:33 PM
  1. #1 Epic Hail Mary 4T65 Build
    GTP Level Member
    Pittsburgh
    So over the Past few weeks I have been building a bad ass trans because of the 2nd IS breaking on me.
    Specs of the Build
    2003 4t65e
    Meziere billet flex plate
    Intnese 300m Input shaft
    Chrome Moly Pump shaft
    Precision 3000 Stall Converter
    Valve body and Channel Plate Modified by TEP
    GMR 1' Chain 3.29
    Hardened 4th Gear
    Raybestos Stage 1 for Input and 2nd Gear
    Raybestos Z pack for 3rd Gear
    Raybestos High Energy 4th Gear.
    Intense Shift kit
    So its been over a year of babying the car. I first Broke my Stock Trans back 2 days before Christmas 2010. Sucked.
    so the trans had to come out
    fast forward to June 2011 and I was hearing weird sounds and issues........
    Here is what I found
    So ya that Trans came out in September
    and replaced with a GM SRTA that i happened to come across at a great price.
    Fast forward to March 2012
    kaboom, broke the stock IS in the GM SRTA trans......so that leads to the epic build.
    so i took a nice tag along ride and dropped it off here at work
    and Started the trans removal
    Makes it nice to have access to this stuff
    2003 SSEi,
  2. #2 Re: Epic Hail Mary 4T65 Build
    GTP Level Member
    Pittsburgh
    Started with the Stock 03 trans what had about 66K on when the IS let go.
    notice the goodyness in the top of the pic
    Found that there are actually output shafts that are used in the 4t65. one is slightly longer
    and also the longer one also has a rib. its supposedly marked as the HD version, but I am unable to confirm 100%
    Intense 300m Input Shaft
    also the reluctor of the GMR set was Bolted by the previous installer
    Welded it so it never becomes a problem.
    I decided to go with the Raybestos Frictions and Steels over the Borg Warner after spending alot of time on the phone with the companies.
    I went with the Stage 1 Red's for Input, and 2nd. Raybestos Z pack for 3rd and Raybestos High Energy for 4th.
    Input (5 clutches instead of the stock 4)
    Here is the Input module assembled (friction and steels)
    Second Gear (added a thicker steel to get the tolerance tighter)
    Second gear module
    Third gear Z pack Module
    Fourth Gear
    Fourth Gear Module
    Also have a modified 3rd gear clutch piston installed in the drum. Its from the 4T60 Trans and has more surface area and is alittle taller to provide the additional clamping force
    2003 SSEi,
  3. #3 Re: Epic Hail Mary 4T65 Build
    GTP Level Member
    Pittsburgh
    i dont have pics of the build because its nothing really special, but i did have to take a pic of the GMR one last time.
    So after it was all together I modified the rear trans mount with some "poly". As most of you know there is nothing made for some old person Bonneville, so you have to improvise.
    New stock Mount
    and fillling it in
    new compared to the old stocker
    Also filled in the Drivers side Trans mount with the "poly"
    Once the Trans was out, switched the flex to the Meziere Billet unit
    As an FYI i also tightened the rear cover bolts. as with every 3800 they were loose
    Also while the trans was out, figured that i would make it pretty. Some rattle can to match the SC and the IC, that was painted in the past.
    Installed the false KR kit or whatever, Put a nice blanket on the Case and wrapped the KR sensor too
    Final part finned AL pan
    After all this crap had 2 minor issues, resolved them thanks to Bill.
    took the car out.......it was amazing
    2003 SSEi,
  4. #4 Re: Epic Hail Mary 4T65 Build
    Well that should hold for quite some time!
  5. #5 Re: Epic Hail Mary 4T65 Build
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    Very very nice! Just one question.... When does mine get here??
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  6. #6 Re: Epic Hail Mary 4T65 Build
    Pennsylvania
    Stellar.
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    Quote Originally Posted by Kejross View Post
    This
    Sent from my Motorola ATRIX 2 on tapatalk
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  8. #8 Re: Epic Hail Mary 4T65 Build
    Great job man!
    Looks awesome.
  9. #9 Re: Epic Hail Mary 4T65 Build
    Love the welded ISS reluctor. Looks just like mine, cept big bad chain. FWIW those bolts appear to look like the Dynotech setup I had taken apart here at some point.
    Hope it holds up for a ya buddy.
  10. #10 Re: Epic Hail Mary 4T65 Build
    Saratoga NY
    Nice work! its nice starting over with a low mileage virgin.
    98-XP e85 SSAC HPT AGX Bullets Every BRM piece home built trans
    99-HPT ssic headers ported blower
    94z28 with a cam that chops so hard it hurts def peopels ears.
  11. #11 Re: Epic Hail Mary 4T65 Build
    Quote Originally Posted by gmpowered View Post
    That all depends.. it gets boring after your 5th-10th virgin.
  12. #12 Re: Epic Hail Mary 4T65 Build
    Pennsylvania
    Oh Bill.
    Deflowering the hell out of transmissions.
  13. #13 Re: Epic Hail Mary 4T65 Build
    Funny part is.. 2003 SSEi murdered my first.
  14. #14 Re: Epic Hail Mary 4T65 Build
    GTP Level Member
    Pittsburgh
    yup, Broke the first of Many for that Bonneville.....
    2003 SSEi,
  1. The Rare, Mary Kay Grand Prix!
    By Brian99SE in forum General Grand Prix Discussion
    Last Post: 08-10-2016, 07:05 AM
  2. "Lil Alky", the epic build thread
    By alkygto in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2012, 04:05 PM
  3. The Hail with it
    By Switzersland in forum General Tech Discussion
    Last Post: 07-19-2011, 11:41 AM
  4. Epic Camaro Build
    By Odi in forum Off Topic Discussion
    Last Post: 01-05-2011, 11:10 AM
  5. hail damage
    By kjohnson in forum The Rant Forum
    Last Post: 04-12-2010, 03:13 AM
