Thread: Some fluid leakage but where???
Results 1 to 10 of 10
  1. #1 Some fluid leakage but where???
    Florida
    Im leaking tranny fluid pretty much everyday but most days its like a dot or two. But every once in a while ill have a small puddle and thats what happened this morning. I havent been able to pinpoint where the hell its comin from, at first i thought it was my gasket but i pour then quickly go under the car and like 10sec later it leaks somewhere above the tranny pan bolts, further up the tranny. It has been like this since i installed my shift kit so what could it be? any help please.
  2. #2 Re: Some fluid leakage but where???
    dip stick tube?
  3. #3 Re: Some fluid leakage but where???
    Florida
    I have the car on ramps right now and did the test again to try and get a better idea but still cant find the source.I pour fluid, look under car, 10secs later i see the fluid trickle down a portion of the tranny and drips from the pan.
  4. #4 Re: Some fluid leakage but where???
    the tube is in the back side above the pan on the d/side, it may have a crack in it, if its leaking right after you pour in fluid.
  5. #5 Re: Some fluid leakage but where???
    Florida
    Ahh that kinda sucks. The odd thing that gets me though is that before i did my shift kit I barely leaked but since then every couple of weeks it would be at least 2-3oz of fluid loss in my driveway. But is it as simple as puling out the dipstick tube and relacing it or do I have to take apart stuff?
  6. #6 Re: Some fluid leakage but where???
    at the bottom of the tube is a 10 mm bolt, remove it, pull tube up, and its out. im not 100% sure but it may have a O ring at the bottom too.
    is that the area the leak is from, d/s back of trans?
  7. #7 Re: Some fluid leakage but where???
    Florida
    Yes thats the area. So it may be the dipstick then. Thanks. Now once i remove the dipstick will i lose a lot of fliud or is it a small amount?
  8. #8 Re: Some fluid leakage but where???
    not sure never yanked one with a full trans, put a small bucket under to be safe.
  9. #9 Re: Some fluid leakage but where???
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Very little fluid will pour out.
  10. #10 Re: Some fluid leakage but where???
    Florida
    Thanks guys
  1. Low Washer Fluid
    By ericrluoma in forum General Tech Discussion
    Last Post: 09-17-2009, 11:11 PM
  2. How much fluid do i need? Thanks
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-22-2009, 07:50 PM
  3. Fluid
    By BwolfGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-16-2009, 11:11 PM
  4. Trans. Fluid?
    By BwolfGT in forum General Tech Discussion
    Last Post: 04-11-2009, 05:26 PM
  5. How much fluid does the s/c take?
    By brodyman in forum General Tech Discussion
    Last Post: 09-17-2008, 02:15 PM
