Thread: Low Washer Fluid
Results 1 to 2 of 2
  1. #1 Low Washer Fluid
    Forest Lake, MN
    I have a 2008 Pontiac Grand Prix GXP with 43,000 miles. This morning after a couple miles down the road, I had a double chime and the message "low washer fluid" displayed on the DIC (driver information center) Obviously, I checked the washer fluid level. Right at the top. I acknowledged the message by hitting the set/reset button. It continues to chime and display a couple minutes after start up, and then for a few seconds when I shut the car down. I've checked the fluid again - still right at the top. I used the wiper fluid and ran it down a little bit and then refilled - same thing. It's not leaking - and It's hard to get at the reservoir as it's tucked behind the battery, under the support, and up against the firewall/fender. What am I missing to get rid of this message? Any help would be appreciated.
  2. #2 Re: Low Washer Fluid
    New Brunswick
    This is most likely caused by a bad ground which is very common, I found this on another forum Grand Prixs Of North America • View topic - stupid washer fluid sensor hope it helps.
  1. Windshield Washer Fluid
    By Pontiac99GTP in forum General Tech Discussion
    Last Post: 09-09-2009, 01:35 AM
  2. Washer fluid wont spray..
    By skubasteve! in forum General Tech Discussion
    Last Post: 12-05-2008, 06:57 PM
  3. Washer Fluid Injection
    By 98GT3800 in forum General Tech Discussion
    Last Post: 10-21-2008, 11:51 AM
