Thread: no 4th gear a WOT please help
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 Re: no 4th gear a WOT please help
    Do you have 3rd if you drive it normal?
  2. #22 Re: no 4th gear a WOT please help
    yeah mine shifted from 1 to 2 like a champ and just screamed, no 3 rd, if i let off it would catch 4 th at around 45 mph.( o/d) and hold tight. and run at 75+ mph no problem at 1800 rmps or so, like it should. but no 3 rd kills you around town.
  3. #23 Re: no 4th gear a WOT please help
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    i dont have that problem yet and yes i have 3rd normally
  4. #24 Re: no 4th gear a WOT please help
    Maybe a solinoid problem then?
  5. #25 Re: no 4th gear a WOT please help
    i'd take it to a trans shop and have them scan it, it may show a code.
    the free auto zone scanner wont cut it for a trans problem code most of the time.
  6. #26 Re: no 4th gear a WOT please help
    Oct 2011
    Michigan
    im hopping its just a solinoid
  7. #27 Re: no 4th gear a WOT please help
    i was also so hoping for a solenoid too.
    ill pray for ya.
  8. #28 Re: no 4th gear a WOT please help
    Oct 2011
    Michigan
    haha thanks man
  9. #29 Re: no 4th gear a WOT please help
    You guys can pray all you want, it's not a soleniod issue.
    Take a look at the trans info/links thread I posted a while back and you'll see that first, second and fourth use the soleniods. Third gear uses no soleniods. The basics are if three of your gears work, that's covering all combinations of on and off for both soleniods, which means when you get to third that doesn't use either soleniod, it should work find because the other three gears do test for both on and off of both soleniods. Hence...this most likely isn't a soleniod issue. Sorrrrrry.
    It is possible there is too much torque/power for the gear to grab and that's why you are bouncing off the limiter. The third gear clutches probably take the most abuse/wear of any clutches in our transmissions.
    Not sure where you are located, maybe you could do a "Scottydoggs" and fix it quick and easy.
  10. #30 Re: no 4th gear a WOT please help
    Oct 2011
    Michigan
    whats that link i cant seem to find it?
  11. #31 Re: no 4th gear a WOT please help
  12. #32 Re: no 4th gear a WOT please help
    Oct 2011
    Michigan
    i was wondering if i took it to a trans shop would they be able to know if it was the 3rd gear clutch with out taking the trans apart? if that was the problem
  13. #33 Re: no 4th gear a WOT please help
    Technically, yes they should. They should be able to test drive it and watch it on a scanner or manually control it. That would allow them to see it engage or not engage 3rd during normal driving and then spirited driving.
    A trans shop buddy of mine, suggested I build a box to manually control a trans I was diagnosing. Works great besides pissing the pcm off. It allowed me to control the trans seperately, but the down side is..you can't see what is actually going on. My HPT allows me to select the gear etc and watch the calculated ratio etc to see what's going on.
  14. #34 Re: no 4th gear a WOT please help
    Oct 2011
    Michigan
    ok thanks man i got a family friend that owns a trans shop but im busy with work so i havent had time thanks for the help though
  15. #35 Re: no 4th gear a WOT please help
    Anytime..I've been through my share of issues and through friendly help have learned and can help out.
  1. Not going into gear at all
    By jwjones in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-18-2012, 04:58 AM
  2. 2nd gear to 4th gear shift
    By 98grannyprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-17-2011, 01:03 AM
  3. no first gear what gives
    By blacksleeper in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-11-2010, 07:49 PM
  4. top gear
    By 1999gt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-07-2009, 08:54 PM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
