Thread: Questions about Transmission Cooling, Worth it on stock or wait until mods performed?
Results 1 to 5 of 5
  1. #1 Questions about Transmission Cooling, Worth it on stock or wait until mods performed?
    SE Level Member Mad Max's Avatar
    Jan 2012
    Kentucky
    I'm a big fan of trans cooling and have no qualms about putting one in. If heat is the number one killer of automatics then I'm all about cooling. I have heard some talk, however, that the stock 04+ GP trans cooling is sufficient for mildly modded cars, so should I bother on a bone stock 05" GTP before I begin modding or can I wait until I'm making more power?
    I was also thinking that an aftermarket cooler would possibly help KR because instead of having hot trans fluid pump through the radiator it is seperately being cooled, so it would help the normal engine cooling by not having that extra part of the radiator being filled with another hot fluid. I noticed the trans cooler on my mustang lowered my normal engine operating temperatures by a few degrees, so I figured it would benefit my GTP for future modding.
    Separate question, would a shift kit and ZZP 1.0 PCM help reduce trans temps at all, raise them possibly? I would think that the less time the trans is soft shifting the less friction build up occurs and therefore less heat, and the increased line pressure, would that effect heat at all?
    What about the aluminum pans with cooling fins, is that more of just a hype thing or does it actually help? I would get the pan simply to have the benefit of a drain plug, but I was just curious if it actually helps to dissipate heat better than the stock units.
  2. #2 Re: Questions about Transmission Cooling, Worth it on stock or wait until mods perfor
    Monitor temps and determine if you need it. Some benefit, some its a hinderence.
  3. #3 Re: Questions about Transmission Cooling, Worth it on stock or wait until mods perfor
    utah
    The finned pan is the one zzp product I will endorse. This transmissions run hot. And everything I've heard from the trans builder say its not heat that kills them but parts failures. Imo a trans cooler (in this app) is just another place for it to leak. Get a finned pan and call it good. If you worried about it grenading, don't mod it, or buy a tep.
  4. #4 Re: Questions about Transmission Cooling, Worth it on stock or wait until mods perfor
    Jan 2012
    Kentucky
    Thanks for the tips.
    I can't help but notice your post times. Either you are all in a close time zone to me in Afghanistan or you never sleep lol.
  5. #5 Re: Questions about Transmission Cooling, Worth it on stock or wait until mods perfor
    utah
    Been there done that....never recovered a normal sleep pattern. It is now my internal clock
  1. cooling system questions
    By ibhuff in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2011, 09:37 AM
  2. transmission cooling lines
    By chancinit666 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-10-2010, 12:46 PM
  3. Work performed over the last two days
    By FuglyGTP in forum General Tech Discussion
    Last Post: 08-30-2010, 10:41 AM
  4. Questions on some mods
    By Everblades2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2010, 06:35 PM
  5. Future mods questions
    By nascartech in forum Introductions/Noob Questions
    Last Post: 03-30-2009, 02:49 PM
