Glad I could help out. The sun gear shaft does push up on the geartrain inside the trans which is why you need to push the final drive inwards to compensate for its endplay. If you just push up on the shaft without the final drive in place it can push in further and give an incorrect reading, that is why the tech manual shows having the final drive end play set first and already assembled.
