Thread: 4t65e air check question
Results 1 to 12 of 12
  1. #1 4t65e air check question
    ma.
    was wondering if it normal on 1998 monte carlo with 4t65e on new rebuild air clutch pack test on 2nd clutch pack to have air coming out on check ball when doing test ?????? all other clutch pack are fine just on 2nd clutch pack
  2. #2 Re: 4t65e air check question
    Jul 2008
    sumter,south carolina
    u would get better responses in the trans section of forum.
    02 GTP with mods 05 GP for DD
  3. #3 Re: 4t65e air check question
    Did you assemble the leg with all the pack together and them test through the hole on the 4th support?
  4. #4 Re: 4t65e air check question
    moved.
  5. #5 Re: 4t65e air check question
    ma.
    yes I put the whole clutch pack together and tested all pack test ok exept for 2 nd clutch with check ball air come out of check ball
  6. #6 Re: 4t65e air check question
    Did you pull it out and inspect it?
    Where in Mass are you.
  7. #7 Re: 4t65e air check question
    ma.
    did get it to work with a little tranny fluid in feed hole put tranny in car and now am getting long shift time from 1st to 2nd when tranny warms up. when cold shift fine throught all gears any ideas on how to fix ???? i have been reading post on issue and maybe valve body or accumalator and ideas. Tranny on rebuild had 200 thousand on it but parts all looked preatty good for mileage .
  8. #8 Re: 4t65e air check question
    Is the valve body all original or did you put any of the sonnax updates into it?
  9. #9 Re: 4t65e air check question
    ma.
    No valve body is original no updates just good cleaning of all valves and put back together
  10. #10 Re: 4t65e air check question
    That may have something to do with it. From what I've heard from builders our valves tend to get sloppy in the bores and cause all kinds of little issues.
  11. #11 Re: 4t65e air check question
    ma.
    Do I need to get a rebuild valve body or have mine rebuild ????
  12. #12 Re: 4t65e air check question
    I'm not an expert, I'd think it's a possibility. Give Dave at TripleEdgePerformance a call and see what his thoughts are. Dave's a great guy and has all the tools to do the full install of all the updates etc.
  1. Have a 4T65E Question? Please Read! Triple Edge contact info
    By Trannyman95 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-29-2023, 02:22 AM
  2. 4t65e HD Rebuild (Question is for Trannyman95 or any other Tranny GURU)
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-18-2013, 01:24 PM
  3. 4t65E replacing 4t65e-hd question
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2010, 10:33 PM
  4. 4T65E-HD Question...
    By WHT98GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-10-2009, 04:53 PM
  5. 4T65E HD tranny swap and perf. shift question
    By daytonapacecarguy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-27-2009, 11:49 AM
