Thread: 4T65E End Play question?
Results 1 to 5 of 5
  1. #1 Re: 4T65E End Play question?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    The final drive endplay is seperate from the overall unit endplay. When setting the main endplay via shim under the bearing on the input clutch drum you need to push the differential towards the transmission to take all of the slack or endplay out of that section. The easiest way to do this without the preload tool showed in the instructions is by having the final drive/differential and tail housing already set up and installed and the transmission standing on this end so the main line of the transmission points straight up and down. Then you can use a flat blade screwdriver or small prybar to pry upwards on the final drive by inserting it through the speed sensor hole in the tail housing. While prying up on the final drive you will check the main line endplay which without the special tool to measure this you will lay a straight edge across the case and use a feeler gauge to measure the difference from the case edge to the top surface of the driven sprocket support and adjust accordingly.
  2. #2 Re: 4T65E End Play question?
    Nov 2011
    Green Bay
    Trannyman,
    You're the best! I figured as much but still have one question if only for my own curiosity. What pushes anything up in the main? It would have to be either the sun shaft or the final drive ring gear being pushed against the big snap ring, wouldn't it? It seems those are the only 2 that would affect endplay in the main and I doubt it is the sun gear shaft. (I could be wrong) Does the sun gear shaft only float in the line so the sun gears can find there own center where they are happy?
    I have the input yoke off an old axle that I put in the final drive. Then I stand it on that yoke and block up the trans so it stands on the yoke. (therefore pushes all up)
    Thanks again for your expert help,
    Mike
  3. #3 Re: 4T65E End Play question?
    Nov 2011
    Green Bay
    Trannyman,
    I just want to say thanks again. I understand everything you explained. It is so much easier when equipped with some knowledge. You did an excellent job of describing things. I am a diesel mechanic and have experience with lots of Alison transmission. These are similar but very different.
    Mike
  4. #4 Re: 4T65E End Play question?
    Fort Wayne, IN
    Glad I could help out. The sun gear shaft does push up on the geartrain inside the trans which is why you need to push the final drive inwards to compensate for its endplay. If you just push up on the shaft without the final drive in place it can push in further and give an incorrect reading, that is why the tech manual shows having the final drive end play set first and already assembled.
  1. 4t65e air check question
    By 57buick in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-23-2011, 12:36 PM
  2. 4t65E replacing 4t65e-hd question
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2010, 10:33 PM
  3. 4T65E-HD Question...
    By WHT98GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-10-2009, 04:53 PM
  4. 4T65E HD tranny swap and perf. shift question
    By daytonapacecarguy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-27-2009, 11:49 AM
  5. Steering wheel play question
    By bula81069 in forum Brakes/Suspension/Chassis
    Last Post: 05-22-2009, 12:22 PM
