Thread: Tranny reinstall help!!!!!!
Results 1 to 20 of 21
  1. #1 Re: Tranny reinstall help!!!!!!
    Calgary
    yeah i didnt fill the TC but i havent put the car into gear yet
    but the dipstick does say that it is up to level, that is before cycling through the gears though
    ... just working out a few tweeks with the new engine.... will post a video when she is all done....all new drivetrain parts, suspension, and engine
  2. #2 Re: Tranny reinstall help!!!!!!
    St. Louis
    That dipstick level will disappear once you try and run through the gears. It should also drop just having the car running so keep an eye on it. The pump turns as long as the engine is running.
    And don't freak out when you are cycling through the gears when it doesn't grab right away. It won't upon the first few fills. Just fill it slowly and run the gears, then check level. Add as needed to bring up to full then cycle again. Once it starts grabbing gears then you know you are close to full. Then once its full go take it for a short drive to get the trans up to operating temp and bring it back home and re-check the level. Add as needed and close er up!
  1. LIM reinstall
    By YoungGTP in forum How To Write-Ups/Tech Tips
    Last Post: 11-10-2013, 07:59 AM
  2. 3.1 tranny on a 3.8?
    By vinny of destruction in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2011, 11:18 AM
  3. tranny
    By mcsddd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2009, 01:01 AM
  4. uninstall & reinstall LIM and SC
    By YoungGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2008, 05:34 PM
  5. Tranny???
    By Darkcelle in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-06-2008, 10:36 AM
