Something's definitely wrong there. Anything above 230* will likely be a problem for you. I've been whomping around steep hills for hours in 97* heat and seeing it occasionally peak at 201*. Perhaps your engine is also overheating? As in low on coolant, have a clog in the coolant lines, or stuck thermostat?
