Could just be a bad thermostat. What kind of temps are you seeing?
its about 245 and when it gets hot , when i give it gas it almost studders a bit then kicks in it power.. I will have to look at having trans oil changed,, might help.. the car is awesome though ..thanks you
Something's definitely wrong there. Anything above 230* will likely be a problem for you. I've been whomping around steep hills for hours in 97* heat and seeing it occasionally peak at 201*. Perhaps your engine is also overheating? As in low on coolant, have a clog in the coolant lines, or stuck thermostat?
