Thread: Noise coming from the transaxle on right turns
Results 1 to 9 of 9
  1. #1 Noise coming from the transaxle on right turns
    Apr 2009
    San Jose, Ca
    Hello, i was on the website last night trying to ask about this noise possibly coming from my transaxle when i make right hand turns. I thought it was the drive axle at first, but when it was changed, the noise was still there. It also isn't the wheel hub as most suggested those along with the ball joint, tie rod end, etc.. So i've uploaded two videos hoping somebody can indicate what it could possibly be. On the first video, the noise will be heared as i make right turns, and the second is some noise the starter makes right when the engine starts. You might have to turn the volume up a little. Thanks for the input.
    transaxle noise video by skunktriscuit - Photobucket
    starter problem video by skunktriscuit - Photobucket
  2. #2 Re: Noise coming from the transaxle on right turns
    Since I'm jealous of year round perfect weather, I'm not helping. That's right.. you suck for living in the land of perfection and your on your own.
    Ok, maybe I'll help a little. Pull the wheels and check the backing plates. These are the metal shields behind the rotor. When you turn the rotors/wheels etc all flexes and that can make them rub. It can sound like an axle/wheel bearing issue.
    Start up.. you mean that odd sound as you let off the starter? Look up starter shimming and try to pinpoint the noise. I think you might need a shim or two.
  3. #3 Re: Noise coming from the transaxle on right turns
    Apr 2009
    San Jose, Ca
    Thanks for the reply, i don't think it's the backing plate because the noise is coming from the transaxle. I did change the driver side axle or cv joint, and it can't be the wheel bearing hub because i can hear the noise slight when the engine is on park or neutral. One question, can you tell me more about the starter shims? Thanks.
  4. #4 Re: Noise coming from the transaxle on right turns
    Apr 2009
    San Jose, Ca
    About the shims on the starter, i don't think my car requires those. my vehicle is a GTP VIN 1.
  5. #5 Re: Noise coming from the transaxle on right turns
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    The first vid sounds like a backing plate to me. The starter sounds like the solenoid isn't backing out of the flywheel fast enough catching the pinion gear on the way out.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  6. #6 Re: Noise coming from the transaxle on right turns
    GT Level Member 04BlackComp_G's Avatar
    Apr 2008
    Rockport, ME
    This man is a God when it comes to these cars. Trust him if he gives you advice. Check it out man.
    2009 G8 GT #1311 of 1949:CTS-V front/Camaro rear brakes, Solo Performance axle back exhaust
    2006 GP GXP: ZZP catback, k&n intake, retrofit headlights, cts-v brakes
    2007 Escalade ESV:family hauler
  7. #7 Re: Noise coming from the transaxle on right turns
    It's ok on the backing plates. Keep in mind the advice we give you is hearing a sound in a vid. We don't usually know history etc. From the info you mention and what I know about these cars..it's pretty tough to say for sure a sound is coming from the trans or a backing plate. If you are confident, I'm cool with that. But then the advice changes to pulling the diff to check it and or rebuilding/replacing the transmission. For your wallets sake, I hope it is something simple and cheap...like a backing plate.
    Here's some shimming info. It sounded from your vid (lacking a description of what the starter was doing.) that it stayed engaged after the car started.
    Starter shimming - Camaro Forums - Chevy Camaro Enthusiast Forum
    FWIw it doesn't matter if previous starters had shims or not, each is a little different. I've had to shim one out of say 150 starters.
  8. #8 Re: Noise coming from the transaxle on right turns
    Apr 2009
    San Jose, Ca
    Quote Originally Posted by torq455 View Post
    Have any suggestions in what i can do with the starter? My car is the (VIN 1) PG260 M starter and i'm also using an optima battery.
  9. #9 Re: Noise coming from the transaxle on right turns
    Dec 2008
    Alabama
    I'd try making sure all contacts are clean and tight. Try shimming the starter. It might be too close and is binding/hanging up on the flywheel. It's reaching but free. Otherwise the solenoid may be bad, or the pinion return spring is weak. Might be time for a new starter.
  1. noise coming from the supercharger??? (video)
    By PhunnyJesta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2011, 08:57 PM
  2. mystery whobble,clacking noise and tendency to get worse in turns
    By THEWADD in forum Introductions/Noob Questions
    Last Post: 04-20-2011, 06:19 PM
  3. odd noise coming from front wheels
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 04-15-2009, 09:32 PM
  4. weird noise coming from engine
    By q1w2e3r4t5 in forum General Tech Discussion
    Last Post: 04-02-2009, 09:59 PM
  5. Grinding noise coming from my engine
    By zeppelinrocks18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 04:24 PM
