Thread: Changing Transmission Fuild
Results 1 to 20 of 37
  1. #1 Changing Transmission Fuild
    SE Level Member 2005GrandPrix's Avatar
    Pittsburgh, Pa
    was it a good idea to change transmission filter and fuild at 51,000 miles in 2005 grand prix
  2. #2 Re: Changing Transmission Fuild
    id do so at 30,000 but thats still low enough, was the fluid burnt up, brown or anything, if it was still nice and red your doing fine.
  3. #3 Re: Changing Transmission Fuild
    Pennsylvania
    Absolutely, 50k is the recommended interval I believe.
    As long as you used Dex 3 or 6, you should be good.
    Are you having problems that you ask that question?
    Edit: Damn you, Scotty.
  4. #4 Re: Changing Transmission Fuild
    Pittsburgh, Pa
    just wondering bout it. no not brown or anything. just dont want anythin to go wrong.
    thought it slipped but doubt it..it only did it when i put it in reverse then forward but may only of did tht maybe cuz i wasnt fully in gear?
  5. #5 Re: Changing Transmission Fuild
    Pittsburgh, Pa
    when did u guys change urs?
    i know some ppl tht dont believe in changing it
  6. #6 Re: Changing Transmission Fuild
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Quote Originally Posted by 2005GrandPrix View Post
    I think you mean most people don't believe in flushing your tranny. Everyone that I have talked to changes it but not a lot of people flush the system.
  7. #7 Re: Changing Transmission Fuild
    having a trans flush is by far the best thing you can do for your trans, only if it has been done at every 30,000 miles from the beginning of its life, if you don't know the repair history just drop the pan and replace the fluid and filter.
  8. #8 Re: Changing Transmission Fuild
    Nov 2009
    ^ I have heard the exact opposite.
  9. #9 Re: Changing Transmission Fuild
    Pittsburgh, Pa
    the guy dropped tht pan and changed filter and fuild was tht right to do?
  10. #10 Re: Changing Transmission Fuild
    Pittsburgh, Pa
    did u change urs
  11. #11 Re: Changing Transmission Fuild
    Grand Rapids, MI
    im kinda one of those people. ive never changed tranny fluid in any car and never had a prob. minivan has 222k miles on stock tranny and fluid. so i mean idk. im terrified to drain tranny fluid in the gtp. its at 97k miles i really dnt wanna set myself up for probs.
  12. #12 Re: Changing Transmission Fuild
    ive heard it both as well, imo its good to have it flushed if you are the first owner and know whats been done to it, some will say if you are over 100,000 miles, and don't know the history to leave it alone, i've seen cars have a flush done with over 100 tho and it never left the garage on its own power, its one of them things, ppl will go back and forth on.
    i used to flush my trucks trans every year, i drove it 30,000 miles a year for 5 years straight, i also had a friend who worked at lube express so i got it done for free, i just tipped the tech who did the work, the jobs not cheap it was at the time 120 bucks, i'm sure it costs more now.
    the flush im talking about is called a T tech, they remove the trans cooling lines from the radiator and hook it up to a tank, that takes out the old and replaces it with new through the intake line, up to 20 quarts, this swaps out the converter as well, they hold up to 9 quarts that dont come out from a pan drop.
  13. #13 Re: Changing Transmission Fuild
    Quote Originally Posted by brandonl2000 View Post
    at 97,000 id do a pan drop and filter, it cant hurt.
    i bought my car with 212,000 and i am scared to death to touch it lol, its had 8 owners, and i dont have a clue whats been done to it before i got it, sept for what i can tell, my lim was done at some point and maybe even the engine or trans was swapped out, every bolt has socket scars so im sure. theres been a lot of stuff done but im unsure of what.
    im just going to leave mine alone for now, when i get my act together im rebuilding my motor and trans at the same time, im thinking one of them tep transmissions, as im not building back to stock, it may even get a whipple blower, i cant wait
  14. #14 Re: Changing Transmission Fuild
    GT Level Member fri3dchick3n's Avatar
    Alaska
    My car was shifting fine for the most part, flushed the tranny fluid and ended up getting it rebuilt..
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  15. #15 Re: Changing Transmission Fuild
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Would any of you recommend a flush on a tranny that has 110,00 miles on it with absolutely nothing done to it? Nothing is wrong with it, but the fluid is definitely brown, but not burnt.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  16. #16 Re: Changing Transmission Fuild
    Grand Rapids, MI
    yeh i see a possible pan drop in the future but right now all i see is getting it fixed. sounds like i have rod knock at idle. thats gonna break the bank tomorrow. fml.
    ha sorry not to thread jack the subject
  17. #17 Re: Changing Transmission Fuild
    Quote Originally Posted by EJOUIE View Post
    thats one of them toss ups, at most maybe do a pan and filter drop, and add a shift kit while you are there.
    no way i'd do a flush with that kind of mileage and brown fluid.
  18. #18 Re: Changing Transmission Fuild
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    ^^didnt you JUST GET THAT CAR!!
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  19. #19 Re: Changing Transmission Fuild
    Newnan, GA
    Well in that case i will leave it be. Instead I will put the money towards the very distant 4t65e swap.
  20. #20 Re: Changing Transmission Fuild
    Pittsburgh, Pa
    Do not change fuild if it was brown i had a 2000 grand prix checked fuild at 114,000 miles it was brown tlked to ppl they said change it....DO NOT. it will start shifting hard banging gears and making a high whinning noise sounds like ur runnin a r/c car lol. looking for trouble when its brown.
  1. H@lp w/Changing SuperCharger Oil & Transmission Oil ( D.I.Y ? )
    By KevSorbo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2010, 06:31 PM
  2. Changing Transmission fluid, how much quarts?
    By Haulero in forum General Tech Discussion
    Last Post: 10-18-2010, 07:56 AM
  3. Changing rad
    By alexo1us in forum Buick Regal
    Last Post: 09-21-2010, 09:23 AM
  4. Tried changing the S/C oil...
    By tayl5645 in forum General Tech Discussion
    Last Post: 09-02-2010, 08:05 AM
  5. changing to a l67
    By srziemkowski in forum Off Topic Discussion
    Last Post: 02-10-2009, 09:44 PM
