Thread: Changing Transmission Fuild
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #21 Re: Changing Transmission Fuild
    Quote Originally Posted by EJOUIE View Post
    Well in that case i will leave it be. Instead I will put the money towards the very distant 4t65e swap.
    my fluids all brown too, thats why i aint touching it either, not knowing the history behind it, just going for a new one down the road, and it shifts just fine too, no problems as of yet. but im sure if i mess with it ill be asking for trouble.
  2. #22 Re: Changing Transmission Fuild
    SE Level Member 2005GrandPrix's Avatar
    Pittsburgh, Pa
    ya thinking it would be good to change it but its not cuz its all down hill from there
  3. #23 Re: Changing Transmission Fuild
    Grand Rapids, MI
    Quote Originally Posted by sportred04 View Post
    ^^didnt you JUST GET THAT CAR!!
    who me??
    yes i did. but somehow i cracked the flex plate. i think when i went thru inspection and did the ebrake test it cracked it. soo idk. but itll be fixed tomorrow. then back on the road
  4. #24 Re: Changing Transmission Fuild
    Pittsburgh, Pa
    no just saying in general wants it brown never change it
  5. #25 Re: Changing Transmission Fuild
    SE Level Member Powertrike's Avatar
    Jul 2010
    MN, US
    Quote Originally Posted by 2005GrandPrix View Post
    Change the fluid. Transmission fluid maintenance is important. If your transmission ****s out after a pan drop and fluid change, it was already going on borrowed time. I would not recommend a flush at that mileage. If your trans is slipping, don't bother. I just changed the fluid/filter on a 4T65e with over 200k miles on the original fluid, it was very dark brown and smelled nasty, but no excessive amount of clutch material in the pan. Shifted better after the service.
  6. #26 Re: Changing Transmission Fuild
    Topeka, KS
    Mine needs changed. My pan is leaking. I have a cookie pan under my car because of it. It kinda changes its self.
  7. #27 Re: Changing Transmission Fuild
    Iowa
    thats one of them toss ups, at most maybe do a pan and filter drop, and add a shift kit while you are there.
    no way i'd do a flush with that kind of mileage and brown fluid.
    but you would put in a shift kit that will stress the seals more with worn out fluid, well 12qts any way dropping the pan doesnt even get half out. I want a serious reason not to flush a trans with old/bad fluid with new after "X" amount of miles? I had a trans with 12,000miles burn up, miles mean very little to transmissions(to a degree, abviously 1,000,000 miles is going to have a signifcant amout of wear) fluid condition, temp and amount of abuse are how transmissions should be serviced. Also the best way I can describe it is would you after 100,000 miles just change the filter and 1 qt of engine oil, I hope not.
  8. #28 Re: Changing Transmission Fuild
    Quote Originally Posted by IAGXP View Post
    shift kit only increases line pressure in the trans, witch tightens up the clutch packs, a good thing, and transmissions run on ATF "trany fluid" not oil, once your fluid is all brown and burn up, its already on its way out, and if you remove all the fluid and put new fluid in there, it will most likely stop working, very fast.
    why? because all the clutch material thats in the brown burn fluid is all thats holding the trans together, so dropping the pan and replacing 8 quarts its a nice trade off, and the shift kit will tighten up the shifts for ya.
    but like i said if its brown its already on its way out, cars with lots of miles and burnt up brown fluid, some never leave the shop bay after a flush some get lucky and its fine for a while, so flush it you want, but best left alone.
    if you got over 100,000 miles and the fluid is nice and red and dont smell, by all means do a flush, the fluid tells the whole story here. red fluid means someone took care of the car and had the fluid changed over the years, brown fluid means neglect and abuse.
    and if you blew a 12,000 mile old trany up you really beat the crap out of your car, or the last owner did, well someone did lets say that.
    and im sure it blew due to hot operating conditions from beating on it. heat is one of the killers for a automatic transmission, next is not doing regular fluid and filter changes.
  9. #29 Re: Changing Transmission Fuild
    Iowa
    Well the trans wasnt babied, but as a gm tech I know that there is a point where the trans is gone and you are begging on borrowed time but if the fluid is just wornout thats differant. You can flush for the first time after 50,000-100,000 miles if the trans was treated alright and the fluid is just changing colors due to age, by all means flush it. If you pull the stick and it smells bad dont flush it, your trans is screwed. Also transmission fluid has lubricating properties, I call it tranny oil for that fact.
    the oil thing is how i explained it because, like I used to be, most know engines but transmissions are like brain surgery. I also agree that maintinace is worth every penny
  10. #30 Re: Changing Transmission Fuild
    Donating Users
    GRAND RAPIDS, MI
    I flushed my trans at 189k without knowing the previous maintenance of the tranny no problem shifted better than ever then did a pan drop with filter at 207k fluid was a little brown but still doing well at 211k.
    2000 Grand Prix SE: Knocking rod mod and broken timing chain mod. L67 coming soon!
  11. #31 Re: Changing Transmission Fuild
    pennsylvania
    so my car has 167,000 should i change it dont know if its ever been changed i was going to change it with trick shift tranny fluid and lucas tranny fluid
  12. #32 Re: Changing Transmission Fuild
    SE Level Member postalc38's Avatar
    Brant, Michigan, United States
    I don't know who mentioned it but the torque converter doesn't hold 9 quarts of ATF. According to my owners manual, it needs about 7.4 quarts after filter replacement, and lists the total capacity at 10 quarts right below it.
    2000 GP - 157K (DD/Crash damaged project)
    1995 Olds Aurora L47 - 222K
  13. #33 Re: Changing Transmission Fuild
    Quote Originally Posted by jspangler22 View Post
    let the fluid tell you if you should or not, if its all burn up and dark and smells bad, don't do it, if its more on the red side do it, only you can smell it and see if its bad or not.
    if you honestly cant tell, find a friend who's got a newer car and do a side by side with their dipstick and compare the two.
  14. #34 Re: Changing Transmission Fuild
    pennsylvania
    I dont get it wouldnt you want to change it if its dark and smells bad or is that cause if i change it it will cause more problems
  15. #35 Re: Changing Transmission Fuild
    Charles City, IA
    If you do a flush and your trans goes out it was boned anyways.
    SMGPFC Two Nipple General
  16. #36 Re: Changing Transmission Fuild
    Trans capacity is 13 quarts per the ATSG manual and GM FSM's.
    I'm all for pan drop and filter service. No matter mileage/fluid. It's a simple fact that automatic transmissions shoudl be serviced. If your fluid is horrible and clogs the filter, then you screwed yourself.
    Screwing yourself usually hurts... either financially or labor wise.
    The trans in my Bonneville was redone at 176K. It was still running fine, sloppy but fine.
    The trans in my Regal is at 181K and exhibited a little odd behavior at 173K. Occasionally does, best I can figure the input piston sleeve is worn...but it hasn't stopped the car yet. Get on it and it's pretty darn good. I'm building it a new trans right now.
    Either way though, anything over 150K miles on a car and an automatic trans doesn't owe that person anything.
  17. #37 Re: Changing Transmission Fuild
    pennsylvania
    yea i was just going to do pan drop fluid change
  1. H@lp w/Changing SuperCharger Oil & Transmission Oil ( D.I.Y ? )
    By KevSorbo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2010, 06:31 PM
  2. Changing Transmission fluid, how much quarts?
    By Haulero in forum General Tech Discussion
    Last Post: 10-18-2010, 07:56 AM
  3. Changing rad
    By alexo1us in forum Buick Regal
    Last Post: 09-21-2010, 09:23 AM
  4. Tried changing the S/C oil...
    By tayl5645 in forum General Tech Discussion
    Last Post: 09-02-2010, 08:05 AM
  5. changing to a l67
    By srziemkowski in forum Off Topic Discussion
    Last Post: 02-10-2009, 09:44 PM
