Thread: Engine will be done soon...What to do w/ Transmission?
Results 1 to 7 of 7
  1. #1 Engine will be done soon...What to do w/ Transmission?
    SE Level Member NineD9GT's Avatar
    Dec 2008
    PA
    So I hope to be above 300 whp with this engine I'm putting together. I'm going to have my trans " freshened up" what should I look into upgrading while its apart. Already bought the transgo kit and going to get a 4th gear shaft. I just can't justify dumping $1900 into a trans for this car. Please tell me it's doable for less.
    99 GP GT L26 bottom end, Intense stage II cam, Ported L67 heads w/ LS6 springs, LS1 valve seals, 42.5# injectors, ported sc/intake, custom LS1 TB and MAF, custom FWI, 3.4 mps, NGK TR6, ZZP wires, 180 stat, etc...
  2. #2 Re: Engine wi be done soon..... What to do w trans?
    Banned
    Sioux Falls, SD
    Quote Originally Posted by NineD9GT View Post
    Ill be in that 300 WHP range, littile higher, and im putting in a gun drilled output shaft, 4340 input shaft, 7/8 3.29 chain
  3. #3 Re: Engine wi be done soon..... What to do w trans?
    At 300WHP you are going to want an input shaft. I'd suggest a 300M or Intense Turbine shaft. A 7/8 chain set is nice to have, although the V8 dual chains should do well around 300hp.
  4. #4 Re: Engine will be done soon...What to do w/ Transmission?
    Mercer, Pa
    I would get a shift kit, mine will chirp second gear now with one. I would rebuild the tranny, the 4th gear splined shaft will need replaced. My car is an 03 but still had worn splines. Dave at tripleedgeperformance seemed to think it was make before all of them were hardened.
  5. #5 Re: Engine will be done soon...What to do w/ Transmission?
    Mercer, Pa
  6. #6 Re: Engine will be done soon...What to do w/ Transmission?
    GTP Level Member
    Pittsburgh
    hardened IS for Sure, dont even mess with the 4340, Go with the Intense IS, that is what TEP Recommends.
    2003 SSEi,
  7. #7 Re: Engine will be done soon...What to do w/ Transmission?
    Dec 2008
    PA
    Great. Thanks for the input guys.
  1. Removing Engine and Transmission together
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-03-2016, 09:32 AM
  2. Engine/Transmission Rattle
    By Pastorchas in forum Introductions/Noob Questions
    Last Post: 09-15-2010, 05:12 PM
  3. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  4. Engine and Transmission Compatability
    By slednut in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2009, 10:20 PM
  5. how many bolts are there from the transmission to the engine???
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2009, 08:16 PM
