Thread: Engine and Transmission Compatability
Results 1 to 10 of 10
  1. #1 Engine and Transmission Compatability
    SE Level Member slednut's Avatar
    Feb 2009
    Canada
    Hello, I just bought a 2000 gtp with about 314000kms on it. Car it self looks new and it very clean and the engine is a good runner still. But the transmission shifts funny between 1st and 2nd when i am accelerating moderately to full throttle. It take about 4 seconds to complete the shift. It doesn't seem to really slip and it doesn't drop into second either. I did a flush and filter change but no difference. I am not to worried about but it, but it is the basis of my question. I have an opportunity to buy a wrecked 2000 Grand Prix GT for fairly cheap. Are the engine and transmission able to swap. I mean i would have to change the supercharger over, but I am not afraid of that. Just wondering what/if their are differences. Any info and help would be appreciated.
    Thanks
    Ryan
  2. #2 Re: Engine and Transmission Compatability
    TDCRacing
    Guest
    The main differences between the two transmissions are the differential. The non GTP cars (GT) have the non HD differential. Also the passenger side axle is different I belive.Everything else will bolt up fine.
  3. #3 Re: Engine and Transmission Compatability
    Barksdale AFB, LA
    He'd need to take the flywheel off the GT engine so the tranny will bolt up. The HD and non-HD use different TC bolt patterns.
    2009 Subaru Impreza WRX STI
  4. #4 Re: Engine and Transmission Compatability
    TDCRacing
    Guest
    Good point.
  5. #5 Re: Engine and Transmission Compatability
    Feb 2009
    Canada
    So... I could switch the final drives and flywheel and it should work just fine. What about engines though. The one i can get only has about 140000km on it.
  6. #6 Re: Engine and Transmission Compatability
    Barksdale AFB, LA
    Quote Originally Posted by slednut View Post
    No, you can't just switch the final drives. The non-HD tranny will have a FDR of 3.29 with either the non-HD diff or the HD diff. So you'll need to get your PCM programmed for that FDR to use that tranny. The only other option is to dig into the side cover and swap the chain and sprockets from the HD to the non-HD. That will give you the 2.93 FDR that GTPs have.
  7. #7 Re: Engine and Transmission Compatability
    TDCRacing
    Guest
    You could keep the 3.29 gears that is in the non-HD transmission and just swap the whole transmission over. But pcm changes will be required. 160 bucks max. I would do it if it was me. If you want to have a lot more get up and go.
    You can also swap the top (from the heads up) of you're GTP engine and put it on the engine you're getting. The compression ratio is higher. But GENERALLY speaking you should be ok. That should also give you an increase in power.
    What I would recomend is doing that....Then get the pcm tuned for that as well....Take care of both the gear change issues and the top swap issues (if any)
  8. #8 Re: Engine and Transmission Compatability
    Barksdale AFB, LA
    Quote Originally Posted by TDCRacing View Post
    ~20HP from what I hear. But who does a stock top swap? So much potential as long as you have the parts off the engine.
  9. #9 Re: Engine and Transmission Compatability
    Oklahoma
    Moved to the correct area..
  10. #10 Re: Engine and Transmission Compatability
    Feb 2009
    Canada
    Ok, Thanks for the help. I am not looking to make power, yet, but i was just wondering if it would work out.
  1. transmission ??
    By french080 in forum General Tech Discussion
    Last Post: 01-18-2009, 03:38 PM
  2. how many bolts are there from the transmission to the engine???
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2009, 08:16 PM
  3. Transmission help.
    By RichCresci in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-03-2008, 03:35 PM
  4. Transmission=Done
    By SLO-6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-30-2008, 01:58 AM
  5. Transmission help needed
    By smokinum in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-14-2008, 10:23 AM
