Thread: Transmission wont reach fourth gear?
Results 1 to 4 of 4
  1. #1 Transmission wont reach fourth gear?
    Quincy, MA
    1997 Grand Prix GTP 3.8 Supercharged
    Hi guys
    THe other day driving on the highway, suddenly I wasnt able to reach fourth gear. I can drive around somewhat normally, but I top at out 35 MPH and the transmission begins to squeal from pushing it too much, I think. Reverse works fine.
    My question is, obviously, what could be the issue? Also, I'm wondering if the fact that I have a faulty MAF sensor has anything to do with it? I read somewhere that a bad MAF can cause shifting problems, and i've had a bad one for a while with the check engine light on, with the code saying it has a low volume.
    Thanks
  2. #2 Re: Transmission wont reach fourth gear?
    as in you can get to the speeds but it wont go in fourth or the engine wont let you go that fast?
  3. #3 Re: Transmission wont reach fourth gear?
    Quincy, MA
    If I start out in Drive, I'll sucessfully shift from 1 to 2, 2 to 3 is a little rough, and then it wont go any higher.
  4. #4 Re: Transmission wont reach fourth gear?
    GTX Level Member cerick08GP's Avatar
    99% chance it is your 4th gear clutch hub in the transmission. The good news is you should be able to limp along without a 4th gear for a month or so. The bad news is a transmission overhaul or replacement is your only option.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  1. 1st gear wont engage
    By dmcglynn in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-09-2010, 02:30 PM
  2. Wont shift into 4th gear
    By youngmcse in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-08-2009, 05:23 AM
  3. Transmission Code and no 4th gear HELP
    By JunkboxGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-23-2009, 02:03 AM
  4. wont move in any gear
    By Thut420 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2009, 09:05 PM
  5. fourth gear gone
    By twistin*6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-29-2008, 08:16 AM
