Thread: What can it be?
Results 1 to 17 of 17
  1. #1 What can it be?
    GT Level Member Louie3's Avatar
    Laguna Vista
    Here are my problems, it shifts up into its forward gears fine but when Im about to stop at a redlight it jerks violently to a stop. Also when I turn into something with out giving gas it slips and then I have to slow down then it jerks into drive.
    ZZP PCM, Wbody PCM, Custom PCM ( the best ), Headers, 3" exhaust, 3.4" pulley, ZZP 10.3 Wires, AL 104's, 160 tstat, 1.9 Rockers, Custom huge cone intake. Gunna push this GTP to the limit.
  2. #2 Re: What can it be?
    How many miles? It might be time for a pan drop and new filter...also...violent chaking might be something else...like a failing motor or transmission mount.
  3. #3 Re: What can it be?
    Laguna Vista
    112k. I'm planing on a flush but if its something else I don't want to waste the monry to find out it needs a rebuild. I checked if it was a mount and its not everything looks nice. Ill probably get it flushed monday.
  4. #4 Re: What can it be?
    Laguna Vista
    So my tranny completely went out last night. I can barely feel it engage like barely feel it and it wont move unless i rev all the way to 5k and it moves at like 1mph. Reverse doesnt work either. so is this a completely needed rebuid or can it be something cheaper?
    I thought reverse would atlease work, In my truck all forward gears went out but reverse was fine, maybe its a FWD thing.
  5. #5 Re: What can it be?
    Buddy had that issue with his Aurora. I'm telling you...pan drop...his was way low on fluid. Like 8-10 quarts low. His did that exact same thing.
  6. #6 Re: What can it be?
    Jul 2008
    sumter,south carolina
    turning and it slipping would indicate low fluid level. whens the last time u checked the fluid.
    02 GTP with mods 05 GP for DD
  7. #7 Re: What can it be?
    I bet it has like 2 or 3 quarts in it and needs a new filter.
  8. #8 Re: What can it be?
    Laguna Vista
    I did check it when the problems rose but the level was fine?
  9. #9 Re: What can it be?
    GT Level Member rmcardle3's Avatar
    Houston, TX
    Running right? Yea, as long as your reading the level while the car is running and then topped it off. Another thing, does it have any kind of a burnt smell to it at all? When you pull the trany dipstick out of the car while it is running, put your fingers on the wet end of the dipstick. Rub your two wet finger tips together. See if it is a burnt smell. Do you smell something burnt on your fingers? Other than that, low level maybe.
    2000 GRAND PRIX GTP (Sedan)
    MICHELIN Pilot® Sport A/S Plus 245/50 ZR16 97W M+S
    Cone Intake, SD Headers
  10. #10 Re: What can it be?
    Laguna Vista
    Of course why its running. It had a slight burnt smell to it.
  11. #11 Re: What can it be?
    Jul 2008
    burnt fluid= no good.
  12. #12 Re: What can it be?
    ^^Yup, drop the pan ALREADY.
  13. #13 Re: What can it be?
    Laguna Vista
    Don't worry I haven't been driving it. I already dropped it off at the shop yesterday
  14. #14 Re: What can it be?
    Da shop?
    Oh boyz
  15. #15 Re: What can it be?
    Laguna Vista
    I was left stranded and I know this guy very well. I can trust him to check out my car. He came with his flatbed and picked up the car.
  16. #16 Re: What can it be?
    Laguna Vista
    I got my car back today and all I can say is Daaaaaaaaamn does she shift beautiful
  17. #17 Re: What can it be?
    Jul 2008
    awesomeness!
