Thread: How To Remove Transmission Help!
Results 1 to 20 of 75
  1. #1 Re: How To Remove Transmission Help!
    Jul 2008
    sumter,south carolina
    BIOOOOOOOOOOOO sticky bills writeup
    02 GTP with mods 05 GP for DD
  2. #2 Re: How To Remove Transmission Help!
    SE Level Member Hixc's Avatar
    Lawrence MA
    So the 4x4 i used snapped and the engine almost hit the ground :O. i resupported it with a cumalong. i just took the cradle off the car. what would be my next step?
  3. #3 Re: How To Remove Transmission Help!
    Stop listening to me if you snapped a 4x4. I've seen a 2x4 used, always use 4x4's myself and can't imagine how you can snap a 4x4 with less than 1,000lbs of weight on it. Were you supporting the motor or the whole car?
    What do you mean, what's your next step? I posted pictures and text saying what should be done to lower a motor and swap a converter. Somehow you already did the impossible.
    Was this 4x4 older than you? How in the holy hell did you snap a 4x4 when it's supporting a motor/trans?
  4. #4 Re: How To Remove Transmission Help!
    Lawrence MA
    i can't believe i posted this... i was such a newb with the gtp at the time. Im doing lots of reading and research these days, now that i have a modded one lol. i believe it was a 2x4, not a 4x4. the 2x4 flipped over on the weak side and snapped. maybee i was drunk. I have a engine hoist now lol
    S1X, TOG, Trannyman Gen3, 3.0/2.8, 42.5#, 105#, Thrasher, Borla PRO XS, Magnaflow Cat, 1.6 roller rocker
  5. #5 Re: How To Remove Transmission Help!
    LOL, probably 2x4. Did you just buy a modded car?
  6. #6 Re: How To Remove Transmission Help!
    Lawrence MA
    yea, i bought one in december all the way in Ohio. drove it back to Mass. blew the stock tranny the first week i had it. finally got it rebuilt, then blew the lower end right after LOL. that is why i'm here, to learn what and what not to do. and i havnt had the money to fix it, not untill now. i hope to have her running again this weekend.
  7. #7 Re: How To Remove Transmission Help!
    SE Level Member Stappen720's Avatar
    RockVegas MA
    This needs a little editing. Other than that this would be the greatest for a sticky. Pictures are KEY. Im currently taking the trans out tonight, and 2morro. One picture that would be nice is where to put the 4x6 or 4x4. In my case i chose the 4x6. If anyone has any pictures on where to put the wood, send me a picture. Either that im winging it 2morro. Just dont want to crush anything important like my fenders or anything.
    2000 Grand Prix GTP -- TEP TRANS , TURBOCHARGED. PT67 /1.9 Mod Rockers/CC Valve Springs 105's/Plog/48lb Injectors / Borla Exhaust/ Cartuning PCM / KYB Struts/K&N Intake/Autolite 103/ SD Appearance Package / Tuned by Deekster Derek and Myself ------------------PB - 13.7 at 102.4 MPH <<< soon to be broken!!!
  1. How TO REMOVE OIL PAN??
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2009, 10:37 PM
  2. how to remove a 97 gp transmission?
    By 1997gp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-13-2009, 12:10 AM
  3. how to remove a 97 gp transmission?
    By 1997gp in forum General Tech Discussion
    Last Post: 07-07-2009, 11:26 AM
  4. Remove cat.
    By bowtechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2009, 02:43 PM
  5. how do i remove the transmission
    By EMerola in forum Pre-1988 3 speed Automatic TH-125C (3T40)
    Last Post: 12-09-2008, 07:28 PM
