Thread: How To Remove Transmission Help!
Results 41 to 60 of 75
  1. #1 Re: How To Remove Transmission Help!
    Well..it's not just 90. You clean the threads. The teflon paste the heck outta the arp bolts and bottom them out. Don't follow the turn til they stop instructions if you want the exhaust to fit. lol (I learned the hard way).
    Then once the teflon has a little time..I copper sprayed the new gaskets on both sides a good thick couple layers, put them on, head on and then 40...50...60...70...75...80..85..90 ft lb torqued them down.
  2. #2 Re: How To Remove Transmission Help!
    Daytona Beach, FL
    What tool is used to put the ARP studs in? Do they have square heads on them?
  3. #3 Re: How To Remove Transmission Help!
    Allen key
  4. #4 Re: How To Remove Transmission Help!
    Daytona Beach, FL
    Just out of curiosity, what would you do,I've got new heads, going to pull the block as I explained, 150k on it, what smart things should I do with the bottom end while i have it out?
  5. #5 Re: How To Remove Transmission Help!
    Daytona Beach, FL
    what is your input on EGR delete?
  6. #6 Re: How To Remove Transmission Help!
    Daytona Beach, FL
    ohh, pulling the block, the bottom motor mount, do you unbolt it and pull it out with the block or do you have to leave the mount and unbolt from the block itself?
  7. #7 Re: How To Remove Transmission Help!
    I don't block EGR's until an IC goes on, typically.
    To pull a motor.. crawl under the car, look at where the motor mount sits in the subframe from underneath. Remove the two 15mm nuts. The mount and bracket will come with the motor.
  8. #8 Re: How To Remove Transmission Help!
    Daytona Beach, FL
    Hey Bill! Ive been talking numbers with my local machine shop that did my heads and like i was saying before that my car got hot and cracked my heads! Do you think that I should have them do rings,bearings,cleaning, seals,polishish crank, basically a short block! they quoted 500 plus parts!
  9. #9 Re: How To Remove Transmission Help!
    Daytona Beach, FL
    with my stock internals
  10. #10 Re: How To Remove Transmission Help!
    I don't know...I've never seen a 3800 get hot enough to crack heads
  11. #11 Re: How To Remove Transmission Help!
    Daytona Beach, FL
    1400 fully rebuilt longblock! Parts included! does that seem reasonable?
  12. #12 Re: How To Remove Transmission Help!
    Sure..especially considering a used L32 about that much.
  13. #13 Re: How To Remove Transmission Help!
    Daytona Beach, FL
    As long as my cam is good, pistons, and dont have to bore!
  14. #14 Re: How To Remove Transmission Help!
    SE Level Member GTPGP98's Avatar
    NorthEast Kansas
    Back to the topic on hand, my brother and I pulled the tranny out of his 99 GTP last night, took about 4 hours to get it out once we realized that we had to pull the subframe out, i just now noticed that it was mentioned in the write-up. I think a picture should be added of it, just to help the next poor sucker out that doesn't like to read notes and looks at pictures instead. Hey, a picture is worth a 1000 words, right?
    All in all it wasn't to hard of a job, we'll see how the new install goes first though.
  15. #15 Re: How To Remove Transmission Help!
    SE Level Member Stappen720's Avatar
    RockVegas MA
    2000 Grand Prix GTP -- TEP TRANS , TURBOCHARGED. PT67 /1.9 Mod Rockers/CC Valve Springs 105's/Plog/48lb Injectors / Borla Exhaust/ Cartuning PCM / KYB Struts/K&N Intake/Autolite 103/ SD Appearance Package / Tuned by Deekster Derek and Myself ------------------PB - 13.7 at 102.4 MPH <<< soon to be broken!!!
  16. #16 Re: How To Remove Transmission Help!
    Reading helps, I even listed socket size.
  17. #17 Re: How To Remove Transmission Help!
    NorthEast Kansas
    I know it does, I really appreciate the work that you did for the right up, especially the picture of where the back tranny bolt was located which was fairly easy to get to with a 3 foot extension.
    We had the tranny loose and ready to drop, that's when we realized that we had to remove the subframe, not to big of a deal. It was harder to get the subframe back in and everthing aligned than anything else. It took us about 4.5 hours to get it out and 6.5 to get it all put back together start to finish.
  18. #18 Re: How To Remove Transmission Help!
    I'll have to go back and look. the subframe going back in for me is typically very easy. Keep in mind, I'm using two jacks, have the axles in, starter is in, it's really bring it up to get the ps rack sitting in place, then hook both balljoints in and then use an alignment bar to get the subframe in the right place. There are holes in it to help do the alignment.
    Not sure if I put that part in there.
  19. #19 Re: How To Remove Transmission Help!
    Apr 2012
    S.C
    Billboost , good writeup and advice from others .Thanks for taking your time . This wil help me out .
  20. #20 Re: How To Remove Transmission Help!
    Glad to be a help..
    If you need any other how to's.. search on "ea sy" without the space and my screen name. It's all out there.
  1. How TO REMOVE OIL PAN??
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2009, 10:37 PM
  2. how to remove a 97 gp transmission?
    By 1997gp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-13-2009, 12:10 AM
  3. how to remove a 97 gp transmission?
    By 1997gp in forum General Tech Discussion
    Last Post: 07-07-2009, 11:26 AM
  4. Remove cat.
    By bowtechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2009, 02:43 PM
  5. how do i remove the transmission
    By EMerola in forum Pre-1988 3 speed Automatic TH-125C (3T40)
    Last Post: 12-09-2008, 07:28 PM
