Thread: 2003 transmission into older 99-02???
Results 1 to 15 of 15
  1. #1 2003 transmission into older 99-02???
    SE Level Member Reverant GTP's Avatar
    Iowa
    Not a lot of information out there about this. Most say its not worth the hassle etc. I just want to know what all this hassle involves? It sounds like I just need a 2003 pcm and use my external range selector and I'm good to go. Can anyone confirm this? Is the pcm itself different or can I just flash the 2003 calibration onto my 2002? Thanks for the help guys.
  2. #2 Re: 2003 transmission into older 99-02???
    If you use a 03 pcm you'll be fine.
  3. #3 Re: 2003 transmission into older 99-02???
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    You need to use the external selector, 2003 PCM Hardware, and a PCM Calibration that matches the year of your car.
    I ran a 2003 Trans in my 99 Regal GS for years with that setup, no issues at all!
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  4. #4 Re: 2003 transmission into older 99-02???
    Iowa
    What do you mean a pcm calibration that matches my car? I finally am getting the transmission this weekend so hopefully in the next month or so I'll have the swap done. It's a 2003 gt trans going into my 2002 gt. I had the guy grab the harness and pcm too as I'm not sure what I'm going to need and not need. I still see people saying just the 2003 pcm and other saying i need the harness too from the 2003.
  5. #5 Re: 2003 transmission into older 99-02???
    Iowa
    I was just going to throw the PCM in and trans in to see what happens. Then pobably unlock it and copy the zzp 1.0 tune for the engine side and leave the trans settings alone for the most part. As I don't know how much different, nor what I'm looking at in the pressure tables.
  6. #6 Re: 2003 transmission into older 99-02???
    May 2012
    Where winter never ends
    I thought the wiring harness, pump, valve body and channel plate were different in the 03....
    2000 Regal - Winter Beater
  7. #7 Re: 2003 transmission into older 99-02???
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Which is probably why you need an 03 PCM.
    04 GTP -HAI, 1.9 rockers.
  8. #8 Re: 2003 transmission into older 99-02???
    Oct 2012
    Pinckney, MI
    You need the 03 PCM, and that should work with your car, no changes.
    You will also need to move the trans range switch from your trans onto the new trans. This lets you re-use your wire harness.
    Other then that, it should be a bolt in and go.
    -Rob
  9. #9 Re: 2003 transmission into older 99-02???
    ^^That.
    And if you don't follow those cues, it'll go into "limp" mode if you will and not shift from 2nd gear. Ask me how I know.
  10. #10 Re: 2003 transmission into older 99-02???
    http://www.grandprixforums.net/threa...a-transmission bills how to says nothing about pcm settings being needed or a newer year pcm.
  11. #11 Re: 2003 transmission into older 99-02???
    I'd rather be safe, than sorry.
  12. #12 Re: 2003 transmission into older 99-02???
    Oct 2012
    Pinckney, MI
    Bills post there seems to be how to add an external range switch. Not how to run a newer trans in an older car.
    -Rob
  13. #13 Re: 2003 transmission into older 99-02???
    that how to is for the newer to older style trans. newer has the electronic switch, the older has the manual switch. so if you need to flip flop one way or the other you swap that pnp switch.
  14. #14 Re: 2003 transmission into older 99-02???
    Iowa
    Thanks Rivman for the help... Just curious do you think I should still be able to use the trans setting from the 02 zzp tune? Then again i could see the 03 being quite a bit different since it a different calibration to control the tranny.
  15. #15 Re: 2003 transmission into older 99-02???
    Dec 2012
    Where 4T65E's were born
    I was just aware that you could swap channel plates/wiring harness, and the external range switch and it would work in an 02 or earlier car. That's everything that changed electrically so the original PCM would work
    Sent from my Nexus 7
    Sold.
  1. How do I know if my transmission is bad or if it is something else? 2003 GT w/ 3.8
    By jevanz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-31-2013, 05:41 PM
  2. 2003 transmission
    By YeahRight in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-14-2011, 10:27 AM
  3. 2003 transmission swap
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-13-2010, 08:33 PM
  4. Transmission lines on 2003 Prix
    By brewtus in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-20-2008, 07:50 PM
