Thread: 05 prix comp edition trans fluid temp question
Results 1 to 9 of 9
  1. #1 05 prix comp edition trans fluid temp question
    Jul 2011
    ridgecrest
    I just purchased an 05 comp edition/supercharged and I was curious if anyone had any issues with the transmission fluid temp staying hot? any suggestions would be great...
  2. #2 Re: 05 prix comp edition
    GTP Level Member AjL227's Avatar
    IL
    Check your coolant level. Bleed the air out of the cooling system.
    It is possible it is time to drop the transaxle pan and change the filter/top off the fluid.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  3. #3 Re: 05 prix comp edition
    Omaha, NE
    Could just be a bad thermostat. What kind of temps are you seeing?
  4. #4 Re: 05 prix comp edition
    Jul 2011
    ridgecrest
    its about 245 and when it gets hot , when i give it gas it almost studders a bit then kicks in it power.. I will have to look at having trans oil changed,, might help.. the car is awesome though ..thanks you
  5. #5 Re: 05 prix comp edition
    Pennsylvania
    Quote Originally Posted by tznitup View Post
    Something's definitely wrong there. Anything above 230* will likely be a problem for you. I've been whomping around steep hills for hours in 97* heat and seeing it occasionally peak at 201*. Perhaps your engine is also overheating? As in low on coolant, have a clog in the coolant lines, or stuck thermostat?
  6. #6 Re: 05 prix comp edition
    IL
    I thought 220 was high. 245 degrees is burning those clutchpacks up quick. You're probably experiencing the transaxle slipping under load.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  7. #7 Re: 05 prix comp edition
    Define hot.
    moved thread.
    changed title to something more useful.
  8. #8 Re: 05 prix comp edition trans fluid temp question
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    I normally see numbers in the 200* range. But maxing at 219*... never near 245*
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  9. #9 Re: 05 prix comp edition trans fluid temp question
    GT Level Member NR92's Avatar
    Atkins, Ia
    my 04 comp g has temps that get up to about 224* and thats after a pan drop, i talked to a trans shop about it and they said 224* is a little hot and recommended "Lubegard BG Transmission Fluid Protectant" Lubegard BG Transmission Fluid Protectant on eBay!, i really have only had it in my transmission for a day, i checked once and my temps were down a bit
    2004 GTP Comp G -- Sold
    2006 GTO Magnuson supercharged
    2007 Ram 2500 QCSB 4x4 5.9 Cummins, Efi live, Exhaust, Intake N'stuff
  1. Grand Prix Gt Limited Edition: Prixy got Ram Air
    By kking89 in forum Members Rides
    Last Post: 06-17-2013, 07:59 PM
  2. 2004 Grand Prix Limited Edition GTP Comp G hood scoop/vents?
    By schlue in forum General Tech Discussion
    Last Post: 01-02-2011, 11:19 AM
  3. Gold edition grand prix gt
    By GoldenGrandPrix98 in forum Visual/Body Modifications
    Last Post: 11-11-2010, 09:44 PM
  4. grand prix dub edition?
    By gtp239 in forum Off Topic Discussion
    Last Post: 07-12-2010, 10:58 PM
