Thread: New transmission not working correct - possible PCM issue?
Results 1 to 20 of 21
  1. #1 New transmission not working correct - possible PCM issue?
    May 2008
    Hi All
    This is my first post... I have owned my Grand Prix GT "40th Anniversary" since new... I have loved every moment.
    Currently I am working towards modifying the car to be a better performing daily driver. To start my modifications I have replaced the stock 4T65E transmission with a performance 4T65E-HD transmission in preparation for a turbo install some time next year. Anyways the new transmission was installed by a respected transmission builder... but there are issues with hard shifting or not shifting correctly under WOT. Below is a list of issues I have encountered...
    1. Shifts hard through all gear shifts.
    2. Under WOT, shifting from 1-2... car hits 6000rpms and then jumps a couple of times before shifting. Seems like a rev limiter engages before the actual shift occurs.
    3. Under WOT, shifting from 2-3... car will not shift unless I pull up on the accelerater. At 6000rpms it seems like a rev limiter engage again (car jumps) but it will not shift until I pull up on the accelerater.
    My transmission installer has checked the transmission over and according to him everything is in good working order with regards to the mechanicals of the transmission. He believes the PCM is the problem. He tells me that the maintained transmission pressure is high at park, "current out of the PCM is sitting at 0.12 to the EPC solenoid, which means high pressure" He says that as the car is put into drive the current jumps up to .88, but then returns to 0.12 and maintains the high pressure.
    The question is... is it likely that I have a PCM problem or is it likely it is something else?
  2. #2 Re: New transmission not working correct - possible PCM issue?
    Barksdale AFB, LA
    What year car did the donor trans come from?
    2009 Subaru Impreza WRX STI
  3. #3 Re: New transmission not working correct - possible PCM issue?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Your problem is that the HD transmission has a different overall gear ratio of 2.93:1, your GT trans has 3.29:1 gearing. You need custom pcm tuning to correct your problem. If you or your transmission guy has a scanner you will find that by looking at the "Current Gear Ratio" info it will read .88 in 3rd gear. It MUST read 1.00 give or take .01 to work properly or it WILL throw an incorrect gear ratio code. When this happens you will have very harsh shifts as the pressure is maxed under most conditions and lockup comes on very hard all the time which is hard on the trans. The gearing changes is made by changing the drive and driven chain sprockets inside the transmission and requires taking the transmission half way apart to do this so its a pretty involving task. Having the pcm reprogrammed will take care of this. There are other ways to get around this but reprogramming the pcm is cheaper and easier to do.
  4. #4 Re: New transmission not working correct - possible PCM issue?
    GT Level Member Preotic's Avatar
    Missoula, MT
    You'll need to change "Gear ratio" and "Pulses per revolution" in your bin file. I had similar problesm last year i went from 2.93's to 3.29's. The tranny didn't know where the torque converter was and it (tc) wouldn't lockup. The tranny constantly overheated because the torque converter wouldn't lockup. Also the shifts were really hard, now matter what i changed to soften them up. Once i put in the correct values all the symptoms went away.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  5. #5 Re: New transmission not working correct - possible PCM issue?
    May 2008
    Thank you for the comments. I think I need to clarify a few things... The transmission was built specifically for the car and has the stock GT 3.29 gears installed. Since the car was a GT stock, I would think that PCM reprogramming would not be necessary, unless having the HD differential also changes overall drive ratio?
    Another note... 245mm torque converter was also installed. Stall set at 2800.
  6. #6 Re: New transmission not working correct - possible PCM issue?
    Barksdale AFB, LA
    Quote Originally Posted by knightmastery View Post
    To become 3.29, the HD tranny would need to have it's chain and sprocket set replaced with some from a non-HD. The HD would then be 3.29 rather than 2.93.
    Still knowing what year would be good.
  7. #7 Re: New transmission not working correct - possible PCM issue?
    May 2008
    Trannyman95... from other posts I have noticed that you have extensive knowledge of transmissions... I am hoping you might have more to say after I clarified that my new transmission has stock GT 3.29 gears and a 245mm torque converter set at 2800 stall.
  8. #8 Re: New transmission not working correct - possible PCM issue?
    May 2008
    The transmission came from a 2002 year GP. It does have the 3.29 gears instead of the 2.93 gears. I had it built that way, specifically to not have to reprogram the PCU until I do a turbo next year.
  9. #9 Re: New transmission not working correct - possible PCM issue?
    Barksdale AFB, LA
    Okay, my lack of GP knowledge here... what year is your car... a "40th" version? Put simply, trannies from up to 02 aren't compatible with 03+ PCMs and vice versa. That's why I'm checking.
  10. #10 Re: New transmission not working correct - possible PCM issue?
    May 2008
    2002 Grand Prix GT "40th Anniversary"... so should be no problem with matching this transmission with this car - right?
  11. #11 Re: New transmission not working correct - possible PCM issue?
    Barksdale AFB, LA
    Nope no problems there. Guess we should look elsewhere...
  12. #12 Re: New transmission not working correct - possible PCM issue?
    Fort Wayne, IN
    Unless your drive and driven sprockets were replace with the correct ones it will throw an incorrect gear ratio code as I mentioned above. Did you check the "Current gear ratio" in 3rd gear yet? Without knowing the data here there is no reason to look into anything else yet.
  13. #13 Re: New transmission not working correct - possible PCM issue?
    May 2008
    Quote Originally Posted by Trannyman95 View Post
    Trannyman... the transmission builder tells me "the gears have 33 tooth drive and 37 tooth driven" for a ratio of 1.1212. The HD differential has a 3.29 ratio. This leads me to believe that the transmssion has a final drive ratio of 2.93 (3.29/1.1212=2.93). Is that correct? If it is correct... then I will have to send back to the transmission builder because I asked him to build me a HD transmission with the GT gearing so that I would not have to change my PCM. If the transmission had the GT gearing then I would assume the drive and driven gears would have the same tooth count - right... say at 35 (half way in between the 33 and 37)?
    Question... how do I determine the differential ratio? Do I take the tooth count from the ring and divid by the tooth count of the sun gear?
    NOTE. I have not changed the PCM from the stock GT.
  14. #14 Re: New transmission not working correct - possible PCM issue?
    Fort Wayne, IN
    If you truely have a 33 Drive and 37 Driven then your builder went in the wrong direction!!! This will give you a 3.69 overall ratio. The HD transmissions have a 37 Drive and 33 Driven, giving you a 2.93 overall ratio. The GT / NA 3800 cars had a 35 Drive and 35 Driven sprocket arrangement. Again, PLEASE check the current gear ratio on a scanner in 3rd gear, there is nothing more to talk about until you check that number unless your builder admits to putting in the wrong gears, which will be proven with a scanner.
  1. DIC not working
    By sausmonkey in forum General Tech Discussion
    Last Post: 04-25-2008, 11:21 AM
  2. gauges not working?
    By s1795so2 in forum General Tech Discussion
    Last Post: 01-13-2008, 12:11 AM
  3. Why is the time on the forum not correct?
    By Andrew_99GTP in forum Forum Bugs/Suggestions
    Last Post: 01-07-2008, 01:38 AM
  4. Power Door Locks not working
    By webracin in forum General Tech Discussion
    Last Post: 12-27-2007, 10:57 AM
