Thread: New transmission not working correct - possible PCM issue?
Results 1 to 20 of 21
  1. #1 Re: New transmission not working correct - possible PCM issue?
    May 2008
    2002 Grand Prix GT "40th Anniversary"... so should be no problem with matching this transmission with this car - right?
  2. #2 Re: New transmission not working correct - possible PCM issue?
    Barksdale AFB, LA
    Quote Originally Posted by knightmastery View Post
    Nope no problems there. Guess we should look elsewhere...
    2009 Subaru Impreza WRX STI
  3. #3 Re: New transmission not working correct - possible PCM issue?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Unless your drive and driven sprockets were replace with the correct ones it will throw an incorrect gear ratio code as I mentioned above. Did you check the "Current gear ratio" in 3rd gear yet? Without knowing the data here there is no reason to look into anything else yet.
  4. #4 Re: New transmission not working correct - possible PCM issue?
    May 2008
    Quote Originally Posted by Trannyman95 View Post
    Trannyman... the transmission builder tells me "the gears have 33 tooth drive and 37 tooth driven" for a ratio of 1.1212. The HD differential has a 3.29 ratio. This leads me to believe that the transmssion has a final drive ratio of 2.93 (3.29/1.1212=2.93). Is that correct? If it is correct... then I will have to send back to the transmission builder because I asked him to build me a HD transmission with the GT gearing so that I would not have to change my PCM. If the transmission had the GT gearing then I would assume the drive and driven gears would have the same tooth count - right... say at 35 (half way in between the 33 and 37)?
    Question... how do I determine the differential ratio? Do I take the tooth count from the ring and divid by the tooth count of the sun gear?
    NOTE. I have not changed the PCM from the stock GT.
  5. #5 Re: New transmission not working correct - possible PCM issue?
    Fort Wayne, IN
    If you truely have a 33 Drive and 37 Driven then your builder went in the wrong direction!!! This will give you a 3.69 overall ratio. The HD transmissions have a 37 Drive and 33 Driven, giving you a 2.93 overall ratio. The GT / NA 3800 cars had a 35 Drive and 35 Driven sprocket arrangement. Again, PLEASE check the current gear ratio on a scanner in 3rd gear, there is nothing more to talk about until you check that number unless your builder admits to putting in the wrong gears, which will be proven with a scanner.
  6. #6 Re: New transmission not working correct - possible PCM issue?
    May 2008
    Trannyman95. You were correct, my math was wrong. They did put in a 33 Drive and 37 Driver for a 3.69 overall ratio. The builder gave me the option of changing out the gears or putting in a new PCM from zzperformance. I went with the new PCM, because I kinda like having the stronger acceleration with the new gears. Everything is working perfectly now.
  7. #7 Re: New transmission not working correct - possible PCM issue?
    Fort Wayne, IN
    Glad to hear you got it sorted out and everything is working right now
  1. DIC not working
    By sausmonkey in forum General Tech Discussion
    Last Post: 04-25-2008, 11:21 AM
  2. gauges not working?
    By s1795so2 in forum General Tech Discussion
    Last Post: 01-13-2008, 12:11 AM
  3. Why is the time on the forum not correct?
    By Andrew_99GTP in forum Forum Bugs/Suggestions
    Last Post: 01-07-2008, 01:38 AM
  4. Power Door Locks not working
    By webracin in forum General Tech Discussion
    Last Post: 12-27-2007, 10:57 AM
