Thread: New transmission not working correct - possible PCM issue?
Results 1 to 20 of 21
  1. #1 Re: New transmission not working correct - possible PCM issue?
    Barksdale AFB, LA
    What year car did the donor trans come from?
    2009 Subaru Impreza WRX STI
  2. #2 Re: New transmission not working correct - possible PCM issue?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Your problem is that the HD transmission has a different overall gear ratio of 2.93:1, your GT trans has 3.29:1 gearing. You need custom pcm tuning to correct your problem. If you or your transmission guy has a scanner you will find that by looking at the "Current Gear Ratio" info it will read .88 in 3rd gear. It MUST read 1.00 give or take .01 to work properly or it WILL throw an incorrect gear ratio code. When this happens you will have very harsh shifts as the pressure is maxed under most conditions and lockup comes on very hard all the time which is hard on the trans. The gearing changes is made by changing the drive and driven chain sprockets inside the transmission and requires taking the transmission half way apart to do this so its a pretty involving task. Having the pcm reprogrammed will take care of this. There are other ways to get around this but reprogramming the pcm is cheaper and easier to do.
  3. #3 Re: New transmission not working correct - possible PCM issue?
    GT Level Member Preotic's Avatar
    Missoula, MT
    You'll need to change "Gear ratio" and "Pulses per revolution" in your bin file. I had similar problesm last year i went from 2.93's to 3.29's. The tranny didn't know where the torque converter was and it (tc) wouldn't lockup. The tranny constantly overheated because the torque converter wouldn't lockup. Also the shifts were really hard, now matter what i changed to soften them up. Once i put in the correct values all the symptoms went away.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  1. DIC not working
    By sausmonkey in forum General Tech Discussion
    Last Post: 04-25-2008, 11:21 AM
  2. gauges not working?
    By s1795so2 in forum General Tech Discussion
    Last Post: 01-13-2008, 12:11 AM
  3. Why is the time on the forum not correct?
    By Andrew_99GTP in forum Forum Bugs/Suggestions
    Last Post: 01-07-2008, 01:38 AM
  4. Power Door Locks not working
    By webracin in forum General Tech Discussion
    Last Post: 12-27-2007, 10:57 AM
