Thread: gauges not working?
Results 1 to 6 of 6
s1795so2 gauges not working? 01-03-2008, 01:56 AM
SyntheticShield I would think if it is doing... 01-03-2008, 08:47 AM
s1795so2 They started working... 01-03-2008, 08:11 PM
Zef_66 Probably a loose or frayed... 01-04-2008, 08:29 AM
03GPScottyd Had a similar problem but the... 01-04-2008, 05:00 PM
Toasty Re: gauges not working? 01-13-2008, 12:11 AM
  1. #1 gauges not working?
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    I was wondering if for some reason the accesory wire in the ignition harness was cut in half, would it make the guages quit working. It is the last thing I touched in the vehicle, even though I would like to believe I would have forgot to tape it up, or solder it or watever. But hey it happens to the best of us.
    Scenario:
    Car cranks fine, guages does full sweep, everything else works including dic, then nothing from the guages not even tach or temp works.
    Is there anything you guys can think of that would possibly be causing this? I am going to be tearing into the car soon to figure this out, so any help would be appreciated.
    -steven-
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
    Oklahoma
    I would think if it is doing the full sweep, then they would have power. But it is odd that none of them are working for you.
    I may need to upload the Grand Prix wiring schematic (its complete as far as I can tell) and see if that becomes useful here.
    alhambra, Il
    They started working magically today, when I cranked it up to pull it in the garage to tear into it. I am still going to see if I can tell what caused it, because it is my luck I will leave it alone and it will get worse progressively.
    Steven Oliver
    PA
    Probably a loose or frayed wire somewhere and those are the worst things to find. A wiring diagram will help. But good luck tearing into it.
    2001 GSE
    Louisville, KY
    Had a similar problem but the outcome was all three guages were ground together. When I grounded them separately they all worked.
    My Cardomain
  6. #6 Re: gauges not working?
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    i'd look more toward the Class II data wire feed from the bcm.
  1. Power Door Locks not working
    By webracin in forum General Tech Discussion
    Last Post: 12-27-2007, 10:57 AM
