Anyone else?
Did you end up checking the wiring yet? When I installed my turbo, there was so much **** over the top of the trans that I couldn't see my harness was touching the downpipe. Burnt through it, trans went in limp mode, I repaired the harness and was back in business. Even if you don't get a voltage code or anything, I would still check it out if your having TCC issues.
I would make a list of everything that has been changed or when it started doing it. Rule out everything.
Definitely check the connections and wiring for the trans since thats what has been reused. Check the wiring for the tcc circuit to make sure its getting proper grnd and voltage from the pcm.![]()
