Thread: Got a new performance transmission built and installed, same problems occuring.
Results 1 to 19 of 19
Lsick7 Got a new performance... 06-14-2010, 01:18 PM
blueguy Re: Got a new performance... 06-14-2010, 11:46 PM
Lsick7 Re: Got a new performance... 06-15-2010, 01:46 AM
Reptile Re: Got a new performance... 06-15-2010, 03:21 PM
QUICKSILVER462 Re: Got a new performance... 06-15-2010, 05:52 AM
blueguy Re: Got a new performance... 06-15-2010, 03:40 PM
nascartech Re: Got a new performance... 06-15-2010, 07:43 PM
Abrasive Re: Got a new performance... 06-15-2010, 10:40 PM
Lsick7 Re: Got a new performance... 06-15-2010, 11:30 PM
Reptile Re: Got a new performance... 06-15-2010, 09:34 PM
blueguy Re: Got a new performance... 06-16-2010, 02:13 AM
Lsick7 Re: Got a new performance... 06-16-2010, 03:17 AM
Reptile Re: Got a new performance... 06-16-2010, 09:39 AM
Lsick7 Re: Got a new performance... 06-16-2010, 05:55 PM
nascartech Re: Got a new performance... 06-16-2010, 08:01 PM
Lsick7 Re: Got a new performance... 06-18-2010, 12:11 AM
Lsick7 Re: Got a new performance... 06-19-2010, 03:15 PM
FoSHO99 Re: Got a new performance... 06-19-2010, 04:15 PM
sic6 Re: Got a new performance... 06-19-2010, 05:00 PM
  1. #1 Re: Got a new performance transmission built and installed, same problems occuring.
    Bastard Reptile's Avatar
    Kansas City, MO
    Does he have a way to watch manifold pressure too to rule out the BBV opening and dumping boost? I know, it's just a thought that Dave ran by me that someone he knows had this sort of issue.
  2. #2 Re: Got a new performance transmission built and installed, same problems occuring.
    Tofu Delivery Boy Lsick7's Avatar
    MO
    Here is a video, the quality is crappy because its from my phone, but listen for the change in exhaust tone at 11 seconds. It feels like the car gets kicked in the rearend and it actually moves, really fast. In the video it reminds of VVT or VTEC the way it changes tone then goes. Just watch and listen, it shifts into second at 8 seconds, then decides to actually rap the gear out and go at 11 seconds. I am at part throttle feathering in first to not blow the tires off, then i'm at WOT at the end of first and the rest of the way.
    Gold Digger - still broke, lawn ornament
    05 M6 PBM GTO - Corsa exhaust, aem intake, bmr drag bags. More whenever I haz monies
  3. #3 Re: Got a new performance transmission built and installed, same problems occuring.
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    thats weird how its bogs then kicks in
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  4. #4 Re: Got a new performance transmission built and installed, same problems occuring.
    MO
    Bump for more input. Brian (Reptile) messed with the tuning a bit and managed to change some things for the better, thanks Brian, but the problem is still a bit there. 1-2 at WOT will sometimes not do it now, but 2-3 is a whole nother story. 2-3 at WOT shifts at around 6k then sits at about 3750 in 3rd for like 6 seconds, ridiculously long, then gets a match lit under its balls and runs like a bat outta hell. I just cant wrap my head around why it's every single gear....
  5. #5 Re: Got a new performance transmission built and installed, same problems occuring.
    MO
    Anyone else?
  6. #6 Re: Got a new performance transmission built and installed, same problems occuring.
    Jan 1970
    Maquoketa, Iowa
    Did you end up checking the wiring yet? When I installed my turbo, there was so much **** over the top of the trans that I couldn't see my harness was touching the downpipe. Burnt through it, trans went in limp mode, I repaired the harness and was back in business. Even if you don't get a voltage code or anything, I would still check it out if your having TCC issues.
    I would make a list of everything that has been changed or when it started doing it. Rule out everything.
  7. #7 Re: Got a new performance transmission built and installed, same problems occuring.
    GT Level Member sic6's Avatar
    san marcos, tx
    Definitely check the connections and wiring for the trans since thats what has been reused. Check the wiring for the tcc circuit to make sure its getting proper grnd and voltage from the pcm.
  1. Transmission/ Coolant Flush Question and Problems
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 07-17-2009, 03:03 PM
  2. A/C Inoperable after transmission installed
    By xxmattfxx in forum General Tech Discussion
    Last Post: 12-25-2008, 11:07 PM
  3. Got my triple edge performance tranny installed
    Last Post: 10-12-2008, 11:08 AM
  4. s1x and built transmission
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2008, 04:56 PM
  5. My official Triple Edge Performance/trannyman95 transmission build review:
    By shaferz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-17-2008, 09:18 AM
